Networks Router control software to limit users speeds?
Discussion in 'Hardware' started by Maniac618, 21 Mar 2006.
  1. Maniac618
    Maniac618 What's a Dremel?
    10 Apr 2004
    Hi everyone,
    are there any programs that can control what speed a user can be limited to etc?
    I have a netgrear dg thingy, that common router.
    Thanks in advance for any help.
  2. Shadow_101
    Shadow_101 Mudkips.
    12 Feb 2004
    In short, with your current kit, no.
    To-do what you require, router side you need packet management /QoS (Quality of Service) to prioritize packets from certain subnets/domains/hosts
    you can achieve this "cheaply" with smoothwall and QoS 2.2 Patch, which allows packet shaping/control and bandwidth throttling.
    Alternatively if you wish to limit another network user’s bandwidth, software is available to limit the amount of bandwidth the host try's to use, but you would need access to the particular host.
  3. CaseyBlackburn
    CaseyBlackburn Network Techie
    27 Jul 2004
    You could run a program called NetLimiter, which I am unsure if you have to pay for it.
  4. Maniac618
    10 Apr 2004
    thanks guys.
  5. ufk
    ufk Licenced Fool
    3 Jan 2004
    net limiter is shareware, but it certainly does that job I use it on my pc's otherwise i just soak up all the bandwidth at home and the landlord gets ****** because he cant use the net
  6. ozstrike
    ozstrike yip yip yip yip
    19 Sep 2004
    Hmm, is there anything I can use similar, but for my linux box? I had it set up to listen to music at school, but it used all the upload so that my dad couldn't connect to t'internet when I was listening at school.
