Windows Router forwarding + VNC remote desktop...
Discussion in 'Software' started by windozesucks, 7 Apr 2004.
  1. windozesucks
    windozesucks What's a Dremel?
    7 Apr 2004
    Hi,
    I have set up my linksys router to forward requests to specific ips.
    Here is what the configuration looks like:
    _________________________
    OSXvnc - port 5900 to 5900 - TCP - 192.168.1.100
    winVNC - port 5900 to 5900 - TCP - 192.168.1.101
    Above those are two different computers on the network running VNC (one is a mac and the other is a pc)
    Obiously there are conflicts with this, as two different computers are using the same port. When I try to connect it simply doesn't work.
    I know how how to change the port # on the OS X vnc version, but do not know how to change the port for the vnc client.
    It would work if I changed the port of both the server and client and than updated the router information.
    Please advise with any tips. :duh:
  2. Bruno_me
    Bruno_me Fake-ad‎min
    30 Mar 2003
    first off, welcome to the boards!
    for connecting use {ip address}:{port}
    you say windows sucks, but you use it ;)
    /me hides the fact that he dual-boots
  3. windozesucks
    7 Apr 2004
    thanks for the tip,
    i was able to figure it out.
    and yes, I do use windows, though its not my OS of choice, and it often crashes, and malfunctions.
  4. ajack
    ajack rox
    17 Apr 2003
    Use nix then :)
