Router help.
Discussion in 'Hardware' started by AJB2K3, 14 Jun 2008.
  1. AJB2K3
    AJB2K3 What's a Dremel?
    12 Dec 2005
    I have one of these power craft routers but it only uses 6 or 8 mm bits.
    All the ones in the stores are slightly bigger then 6mm. Can I get an adaper in the UK to use these normal 6.something bits?
  2. jonatron
    jonatron What's a Dremel?
    1 Sep 2005
    I'm not familiar with that particular make of router, but it sounds like you need a 1/4" collet that fits your router and will allow it to use the 1/4" router bits (nice picture to explain what I mean here). Tooled-up.com sells these, but I don't know which one will fit your router.
    I'm sure 8mm to 1/4" collet adaptors exists as well.
    Hope this helps a little.
  3. AJB2K3
    12 Dec 2005
    More then you know, I didn't know you could buy the collets separate, looks like I need to work out the collet size and order a 1/4 inch (bah stupid uk with its cm/mm measurements.
