Networks Router Upgrade
Discussion in 'Hardware' started by Kronos, 18 Dec 2014.
  1. Kronos
    Kronos Multimodder
    6 Nov 2009
    After three attempts and two resets finally got the Synology DS115J up and running, woeful lack of instructions. Anyway in the top right corner I have the message: "We have detected that your Ethernet speed is 10/100mps only. it is recommended upgrading your router to at least 1Gbps".
    I currently have the Netgear N300 what or even should I upgrade my router with. I would prefer Netgear as I have always found them reliable. Or do I need to bother?
  2. Jim
    Jim Ineptimodder
    2 Sep 2007
    No need to change the router, you can just get a Gigabit switch and run your wired network off that. One of the ports will go to the router to provide internet access to the network.
    They're very cheap, so worth doing IMO if you're going to move large files around the network.
  3. deathtaker27
    deathtaker27 #noob
    17 Apr 2010
  4. Kronos
    Kronos Multimodder
    6 Nov 2009
    OK guys being the idiot that I am where would this go on my system. I already have a switch or hub near my PCs whilst the router is in the living room next to the main phone socket.
  5. wyx087
    15 Aug 2007
    You'll need to connect it like this: (the BiPAC is the switch)
    Basically your PC connects and NAS connect via gigabit switch. That's more or less how mine is set up. I use the same TP link switches, blue metal ones.
  6. Kronos
    Kronos Multimodder
    6 Nov 2009
    Cheers Wuyan, that is nice and simple just buy a new one and put it in the same position as my current one. Thanks.
  7. Kronos
    Kronos Multimodder
    6 Nov 2009
