HTPC RPI B+ Transcoding?
Discussion in 'Hardware' started by theoriginaltomato, 6 Nov 2014.
  1. theoriginaltomato
    theoriginaltomato What's a Dremel?
    5 Nov 2014
    I'm looking to create a HTPC to serve media to my Chromecast, ideally using Plex.
    I had a play around with a RPI model B a while back and found that it didn't really have enough power to transcode video for live streaming. Has anyone had a chance to test this on the more powerful B+? I couldn't see any change in processor spec, so expecting it to be little better at best.
    Thanks!
  2. Votick
    Votick My CPU's hot but my core runs cold.
    21 May 2009
    The processor is the same, It's just a little lighter on power usage and a slightly diffrent layout on the board.
  3. loftie
    loftie Modder
    14 Feb 2009
    Convert everything using handbrake and then it shouldn't need to transcode when you're watching it.
  4. Votick
    21 May 2009
    This ^^
  5. Gareth Halfacree
    4 Dec 2007
    As Votik said, there's no difference in performance between the B and the B+. Same memory, same processor, same everything. The B+ just has a new layout, more reliable power supply and extra GPIO pins and USB ports. If you're trying to transcode, any Pi is the wrong tool for the job.
