Ok, when i start RTCW I get the following erorr... Code: Wolf 1.0.0 win-x86 Nov 13 2001 ----- FS_Startup ----- Current search path: C:\PROGRA~1\RETURN~1\main\sp_pak2.pk3 (232 files) C:\PROGRA~1\RETURN~1\main\sp_pak1.pk3 (1342 files) C:\PROGRA~1\RETURN~1\main\pak0.pk3 (4775 files) C:\PROGRA~1\RETURN~1/main ---------------------- 6349 files in pk3 files execing default.cfg couldn't exec language.cfg couldn't exec wolfconfig.cfg execing autoexec.cfg Hunk_Clear: reset the hunk ok ...detecting CPU, found AMD w/ 3DNow! Bypassing CD checks ----- Client Initialization ----- Cmd_AddCommand: map_restart already defined ----- Initializing Renderer ---- ------------------------------- ----- Client Initialization Complete ----- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'C:\WINDOWS\System32\opengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using desktop display depth of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 8 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...setting mode 3: 640 480 FS ...using colorsbits of 16 ...calling CDS: ok ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ...assuming '3dfxvgl' is a standalone driver ...initializing QGL ...WARNING: missing Glide installation, assuming no 3Dfx available ...shutting down QGL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- GLW_StartOpenGL() - could not load OpenGL subsystem Quake III works fine. I am using Detonator 30.0 on Inno3D GF2Mx 64Mb. Any ideas?
I noticed you are running the v1.0 of RTCW. There is a v1.33 patch out, might try it and see if that helps. Otherwise you might hafta re-install it.
