Hi all, I had RTCW for a while on my older computer. But didn't install it on my new system yet. So today I did. But when I want to start up the game, I get an error. Code: Wolf 1.33-MP win-x86 Jun 1 2002 ----- FS_Startup ----- Current search path: I:\PROGRA~1\RETURN~1\main\mp_pakmaps6.pk3 (81 files) I:\PROGRA~1\RETURN~1\main\mp_pakmaps5.pk3 (35 files) I:\PROGRA~1\RETURN~1\main\mp_pakmaps4.pk3 (52 files) I:\PROGRA~1\RETURN~1\main\mp_pakmaps3.pk3 (83 files) I:\PROGRA~1\RETURN~1\main\mp_pakmaps2.pk3 (47 files) I:\PROGRA~1\RETURN~1\main\mp_pakmaps1.pk3 (34 files) I:\PROGRA~1\RETURN~1\main\mp_pakmaps0.pk3 (21 files) I:\PROGRA~1\RETURN~1\main\mp_pak4.pk3 (5 files) I:\PROGRA~1\RETURN~1\main\mp_pak3.pk3 (76 files) I:\PROGRA~1\RETURN~1\main\mp_pak2.pk3 (3 files) I:\PROGRA~1\RETURN~1\main\mp_pak1.pk3 (308 files) I:\PROGRA~1\RETURN~1\main\mp_pak0.pk3 (783 files) I:\PROGRA~1\RETURN~1\main\mp_bin.pk3 (4 files) I:\PROGRA~1\RETURN~1\main\pak0.pk3 (4775 files) I:\PROGRA~1\RETURN~1/main ---------------------- 6307 files in pk3 files execing default.cfg couldn't exec language.cfg couldn't exec wolfconfig_mp.cfg execing autoexec.cfg Hunk_Clear: reset the hunk ok ...detecting CPU, found AMD w/ 3DNow! Bypassing CD checks ----- Client Initialization ----- ----- Initializing Renderer ---- ------------------------------- Loaded 714 translation strings from scripts/translation.cfg Loaded 97 translation strings from translations/rocket.cfg Loaded 86 translation strings from translations/dam.cfg Loaded 114 translation strings from translations/tram.cfg Loaded 57 translation strings from translations/chateau.cfg Loaded 54 translation strings from translations/keep.cfg Loaded 73 translation strings from translations/icelab.cfg ----- Client Initialization Complete ----- ----- R_Init ----- Initializing OpenGL subsystem ...initializing QGL ...calling LoadLibrary( 'I:\WINDOWS\system32\opengl32.dll' ): succeeded ...setting mode 3: 640 480 FS ...using desktop display depth of 32 ...calling CDS: ok ...registered window class ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 32, 24, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...setting mode 3: 640 480 FS ...using colorsbits of 16 ...calling CDS: ok ...created window@0,0 (640x480) Initializing OpenGL driver ...getting DC: succeeded ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...GLW_ChoosePFD( 16, 16, 0 ) ...35 PFDs found ...GLW_ChoosePFD failed ...failed to find an appropriate PIXELFORMAT ...restoring display settings ...WARNING: could not set the given mode (3) ...shutting down QGL ...unloading OpenGL DLL ...assuming '3dfxvgl' is a standalone driver ...initializing QGL ...WARNING: missing Glide installation, assuming no 3Dfx available ...shutting down QGL ----- CL_Shutdown ----- RE_Shutdown( 1 ) ----------------------- [B]GLW_StartOpenGL() - could not load OpenGL subsystem[/B] GLW_StartOpenGL() - could not load OpenGL subsystem I assume it has something to do with the graphics card. But I'm using the same graphics card as I was on my old system. (I'm still awaiting the delivery of my new Radeon 9800Pro). What am I doing wrong? Thanks, In the meantime, I'll check for drivers for the card. But since other games work fine, I didn't know if this was the problem. (NFSP U2 for example, works fine) L
