Cooling Rubber fan mounting pins
Discussion in 'Hardware' started by DragunovHUN, 9 Aug 2009.
  1. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    These seem to come in two different sizes. A short one and a long one. I'm guessing they're for different mounting "situations", but where should i use them?
    I haven't seen them in action yet and there are several ways you can go about mounting the same kind of pin, so can someone explain them to me? With pictures if possible.
    Thanks
  2. capnPedro
    11 Apr 2007
    Use long ones:
    Use short ones:
    Can you see the difference between the open/closed frame? (Look where the screws would go in!)
    DragunovHUN likes this.
  3. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    Ah, yes, now i see. It all makes sense now, thanks mate! (never had a closed frame fan before)
    +rep
  4. capnPedro
    11 Apr 2007
    I hadn't either until I bought some of that model Yate Loon. In fact, the only way I could find a picture of one was to go to the website I bought the fans from, so as far as I know they're not too common. However, you'd be annoyed if you went to install it and the rubber mount didn't fit all the way through.
