Thats right! a USB Rubiks Memory Cube! The pen drive I had fit perfectally inside the cube, and although it will never actually be rotatable ever again, it is sooo much cooler.I'm not sure what else I'm going to put on it. Perhaps lights, I dunno. Yes I solved it. My best time is 2 min 10 seconds
Pretty cool, but kinda defeats the purpose of having a little usb drive to carry around It would be cool if someone built a rubiks cube that had semi-transparent, colored cubes with lights in it
Very cool work man Atleast you put it into a finished cube nothing worse than a Rubix Cube that isnt done Lights in it would be pretty cool some sort activity lighting etc would be cool
Looks nice, but the drive's not really portable anymore is it? [Unless you never take it anywhere of course ] [EDIT: sorry, TM got there first!]
nice job but 1 thing still bothers me how do you connect the drive to your pc? with an extension cord? and i have an for modding it the colors are green, blue, red and yellow right? whell those colours all are available in leds a blue side, a red side etc do the math i think that would look really cool but its all up to you keep moddin stuff ya hear
ya the pen drive came w/ a cord so i use that. The colors are red yellow white green blue orange red so I suppose I could wire one up to each side but where would I get the power from? only 5v in a usb cable right?
no, its too cramped in there to do that. The bottom of the drive is sitting on the bottom layer of plastic on the very bottom cube. Its a really tight fit and I had to sand a whole bunch of plastic.
Awesome TechZimmy! I love the look of the Rubiks Cube. I moved the thread to modding as it doesn't really qualify for project logs (no work in progress pics, it's a finished mod, etc). Nice work. How does it go when your USB ports are low down near the surface of a desk (e.g. LianLi front USB ports), is there enough room to insert it?
lol very nice... they have alot of stuff like that in japan.. jsut check out this USB ducky... its suposedly called the iDuck...
