Electronics Rubycon or Sanyo capacitor?
Discussion in 'Modding' started by psYCHopath, 20 Jul 2005.
  1. psYCHopath
    psYCHopath What's a Dremel?
    25 Dec 2001
    One of my Leatek Winfast GeForce 4200 TI A250LE MyVIVO capacitor is "pregnent" so i have to change it.
    The original capacitor is
    1000uf
    6.3v
    GSC
    RE105c
    now the problem is which capacitor is better?
    Sanyo or Rubycon? both have the same spec..
    *BTW does capacitors have ampree? :grr:
  2. cpemma
    cpemma Ecky thump
    27 Nov 2001
    One of the spec items will be ripple current rating, higher is better. But physical size may be the decider.
  3. SteveyG
    SteveyG Electromodder
    23 Nov 2002
    Both makes are well known and of good quality, so either would be fine. Higher ripple current rating is better.
  4. psYCHopath
    25 Dec 2001
    wut is ripple current rating?
    physical size...means the bigger the better?
  5. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Get the sanyo, Rubycon is a popular soft drink :worried:
  6. psYCHopath
    25 Dec 2001
    wut softdrink?
    Highland3r do u know wut is ripple current settings?
  7. cpemma
    cpemma Ecky thump
    27 Nov 2001
    No, it means one may be too big to fit in the space available.
  8. ConKbot of Doom
    ConKbot of Doom What's a Dremel?
    2 Jul 2003
    I got a bunch of rubycon photoflash capacitors.... good for making big bangs. Other assorted brands also, but Rubycon seemed pretty popular with disposable camera manufacturers. :lol:
  9. psYCHopath
    25 Dec 2001
    i used the sanyo instead cuz most of the cap is sanyo brand...scared of compatibility problem arise
  10. Holst
    Holst What's a Dremel?
    17 Nov 2001
    Pretty much as good as each other. IMO.
