News Rumour - AMD Radeon HD 7000 supports PCI-E 3
Discussion in 'Article Discussion' started by arcticstoat, 29 Jul 2011.
  1. arcticstoat
    arcticstoat Minimodder
    19 May 2004
  2. bowman
    bowman Minimodder
    7 Apr 2008
    Um.
    This is like platter-based hard drives supporting SATA 3.
    Neat, but pointless.
  3. misterd77
    misterd77 What's a Dremel?
    18 Apr 2011
    500 watt gpu's ?
  4. Tattysnuc
    Tattysnuc Thinking about which mod to do 1st.
    19 Jul 2009
    With the way that Power supplies have evolved, I don't believe that the motherboard will be able to ever power the top GPU models, There must be all sorts of issues with running such high power over printed circuit boards on tracks - how much can be run before you get problems with arcing, or pin burnout etc. Makes sense to keep them isolated and use the 80/20 rule. Surely 80% of GPU's around the world are covered by this power envelope, especially bearing in mind that most boards now have an "APU" to misuse AMD's acronym...
  5. TAG
    TAG What's a Dremel?
    7 Aug 2002
    They're skipping 32nm and going straight to 28nm.
    Next gen GPUs will hopefully use a lot less power.
  6. Goty
    Goty Minimodder
    13 Dec 2005
    Why use less power when you can increase performance. ;)
  7. BrightCandle
    BrightCandle What's a Dremel?
    30 Apr 2009
    300W is not unreasonable for a GPU maximum. There comes a point where its impossible to cool it even with the additional slot they currently use. Noise on the 300W cards is higher than is reasonable.
  8. Evildead666
    Evildead666 What's a Dremel?
    27 May 2004
    300W is probably the max that should be allowed for Graphics cards anyway.
    PCIe 3 will mean better multi-card support, and higher upload/download bandwidth for those cards that may speak directly to the CPU.
  9. azazel1024
    azazel1024 What's a Dremel?
    3 Jun 2010
    I certainly don't think this is pointless. For actual graphics card performance I don't think it'll do a lick of good.
    HOWEVER, for the Bus itself and small add on cards it'll be enormous. A lot of current SATA3 and USB3 add-on cards are limited by being connected through a PCI-e 2 x1 lane. Bump that to PCI-e 3 and you have enough bandwidth to saturate SATA3 and USB3. Also you now are able to get 4 port GbE NICs on a single lane, 10GbE NICs on a single lane. Go with Intels suggested/recommended new x2 lane setup and you have the equivelent of a full on PCI-e 2 x4 lane slot for things like 4 port RAID cards, etc. You could also start implementing new graphics cards standards that run off a lowly x4 PCI-e port if you wanted to (most lower end cards currently don't even really saturate a x8 PCI-e slot).
    You also have twice the total bandwidth on the bus. Especially useful for entry level Intel CPU/chipsets that only support x16 lanes of PCI-e. You use most of that with a single high end discrete GPU. Obviously you aren't going to be using much of that bandwidth for other things when you are gaming, but think of a couple high end discrete GPUs in crossfire, combined with a GbE NIC (or worse a 10GbE NIC) passing large amounts of info and a x4 RAID card making a backup over the network. You are going to be mashing a god awful amount of data through a "restrictive" bus.
  10. Hakuren
    Hakuren What's a Dremel?
    17 Aug 2010
    PCI-Ex 3.0 yes, it is useful now, but certainly not for VGAs. Not one, currently available, graphic card can saturate x16 slot. Today VGAs are barely capable of saturating x8 slot (and that only for top of the line products). So Gen.3 x16 slot is way too soon for graphics.
    Storage that is another matter. It is - pretty much - the only major branch of IT industry which will benefit from more bandwidth introduced with Gen.3. It will simplify manufacturing process by reducing number of x16 slots. x8 slot will provide as much bandwidth. And for entry level servers and workstations I can see moving back to x4 slot which will provide same amount of bandwidth as Gen.2 x8.
    300W limit. Hmm that is a tough one. I would gladly see limit reduced. There is no hope in hell to see any major breakthrough in the way modern PC is created. Of course as everybody I would love to see CPU with power of 30x i7 or VGA with GTX580 performance multiplied by 30 and both draining 5W. But that won't happen for next 50 years or so. And at that point I won't care too much about PCs! :D Anyway, I think there should be tendency to create bigger PSU to feed power directly instead stressing motherboard circuitry.
  11. schmidtbag
    schmidtbag What's a Dremel?
    30 Jul 2010
    I completely agree. If there are any devices that actually use 100% of the PCIE 2 bandwidth then there's probably less than 3 of those products altogether. I would be interested to see how today's top-end GPUs and SSDs perform on pcie 3 but I'm sure it's probably going to be a 1FPS difference.
    As for PCIE 3 not upping the wattage amount - good. Both AMD and Nvidia should not have made cards that exceed that limit. I think it's stupid that they're trying to make these behemoth cards that are so big they can't fit in the average case, spew so much heat that you need to water cooling them, probably consume more power than all of your other electronic devices combined, and in games gives you far more FPS than physically possible to notice.
    The power limitation on PCIE helps keep practical products.
  12. the_kille4
    the_kille4 Chaos will rule da world.eventually
    28 Aug 2009
    I would love to see an affordable way of having SSDs in PCI-E slots... because the current ones are usually meant for servers and using the extra bandwith can definately help their performance
  13. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    Question: Is 300W the maximum bus power draw (i.e; how much you can draw via the card edge connector before needing additional power connectors), or the rated total power draw (i.e; if you draw more than this amount of power, from all sources to a single card, that card cannot be certified as "PCI-E" compliant)?
    The former seems unlikely, but is the latter really an issue? Other than not being able to write PCI-E anywhere on your box, documentation, website, etc (I'm sure some creative workarounds could be found), is there something else that prevents manufacturers from breaking this part of the spec? Some sort of patent agreement whereby non-compliance with any part opens you up to being sued for even using something that is partially compatible with PCI-E?
  14. borandi
    borandi What's a Dremel?
    27 Jan 2010
    There were two 600W GPUs on show at Computex, one of which was definitely being put into production.
  15. Psy-UK
    Psy-UK What's a Dremel?
    22 Jan 2009
    Glad they've kept the power limit. Stops things getting silly and out of hand.
  16. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    sure it wont use what is offered in PCI-E 3.0 but it will help push the way for other devices that will.
  17. law99
    law99 Custom User Title
    24 Sep 2009
    it would be interesting if they just threw powerconsumption to the wind for a single product. But otherwise I'm pleased they want to keep sensible limits.
  18. Action_Parsnip
    Action_Parsnip What's a Dremel?
    3 Apr 2009
    EVERY OTHER process change ever says your wrong.
  19. TAG
    7 Aug 2002
    40nm saw vapor chambers getting the norm.
    They pretty much ran out of better ways to cool smaller surfaces.
    I'm really curious as to what's gonna happen next. What will be used to increase cooling power? Artificially make chips larger by compartimentalising them into blocks deliberately spread appart from each other?
  20. TAG
    7 Aug 2002
    Also, look at laptops.
    They got more powerful AND use less power.
Tags: Add Tags
