News Rumour - Apple to ditch Intel for ARM
Discussion in 'Article Discussion' started by arcticstoat, 6 May 2011.
  1. jrs77
    jrs77 Modder
    17 Feb 2006
    What do you consider low-power Nexxo? Isn't 17 Watt for the newest i5/i7 chips considered low-power anymore? And they sure are way more beefy then currently available ARMs.
    Intel does have the ability to produce beefy low-power chips imho, they only didn't put that much efforts into that direction during the last few years.
    However, looking into the specifications for the current Atom Z-series, they're allready very much low-power with some 2.4 Watt for a 2GHz Z550 -> http://www.intel.com/de_DE/products/processor/atom/index.htm#specifications
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
    Yes, however the chances of Mac OS and Windows getting more and more similar (and with it applications) is certainly higher than if they are designed from ground up for different hardware. Sure, it didn't happen for Linux which is still very different from Windows, but Apple wants the Consumer market to buy its products, so they have to move their OS closer to Windows anyway.
  3. Flibblebot
    Flibblebot Smile with me
    19 Apr 2005
    ...but MacOS is based on Unix, so it's a lot closer to Linux than it is to Windows.
    Most major applications are available for both platforms anyway, so similarity or not is a moot point.
    I think Apple are quite happy being seen as an "elite" brand since it means that they can charge a price premium for their systems, despite the fact that a MacBook is virtually identical in terms of hardware specs to any other laptop.
  4. Horizon
    Horizon Dremel Worthy
    30 May 2008
    what he said, MS has made it known that they are work on a version of Windows 8 the runs on ARM, what possible reason would apple have not to do the same.
  5. Nexxo
    23 Oct 2001
    As in: suitable for mobile devices. The Atom does not have a brilliant performance to power consumption ratio. This is made even worse by combining it with a chipset that uses five times as much power as the Atom does. Nuts. Meanwhile we have the ARM, VIA Nano and nVidia's Tecra being carefully designed for mobile applications.
  6. leveller
    leveller Yeti Sports 2 - 2011 Champion!
    1 Dec 2009
    As far as I know Intel haven't issued a statement to deny this and it would be in their interest to do so ... so it could very well be true!
Tags: Add Tags
