News Rumour: Radeon HD 4890 coming in April
Discussion in 'Article Discussion' started by CardJoe, 16 Feb 2009.
  1. CardJoe
    CardJoe Freelance Journalist
    3 Apr 2007
  2. V3ctor
    V3ctor Tech addict...
    10 Dec 2008
    Regular HD4870 can do 820Mhz in the Core, and the memory can get those 3.6Ghz... so... I just hope that is has some more transistors under the hood..
  3. Goty
    Goty Minimodder
    13 Dec 2005
    A voltage bump would be kind of scary with ATI's stock cooling. Hopefully they either A) come out with a new cooling solution or B) have tweaked the design enough to bring down the power consumption a bit.
  4. Jack_Pepsi
    Jack_Pepsi Clan BeeR Founder
    24 Apr 2006
    I just want the price of the 4850 to drop to £100 or lower.
    :D
  5. wiak
    wiak What's a Dremel?
    9 Apr 2006
  6. Farting Bob
    Farting Bob What's a Dremel?
    21 Jan 2009
    I would hope that this new card uses less power than original 4870's. It'll be ~9 months since the 4870 was released, plenty of time for them to work on reducing power consumption to offset the speed increase.
    And i wonder if the next generation will be the first to actually have LOWER power needs than the previous gen? GPU power consumption cant continue to go up. Idle power is pretty good, but once you start using the card even a mid range card these days will use more than all your other componants combined.
  7. HourBeforeDawn
    HourBeforeDawn a.k.a KazeModz
    26 Oct 2006
    lol and I bought a couple of 4870 a couple months ago... eh thats what always happens lol oh well probably not really worth the upgrade from 4870 to 4890 so I will hang tight for the 5k series ^__^
  8. V3ctor
    10 Dec 2008
    I'l hold for the 6k Series... ^_^ I'm just going to change my Q6600+HD4870 in 2011 or so when Sandybridge arrives... To me HD4870 is more or less like 9700PRO... great bang for buck, and I hope it lasts until 2011 ^_^
  9. loftie
    loftie Multimodder
    14 Feb 2009
    Sounds pretty good, though I agree with the power and heat problems. The 4870 ran pretty hot and so did the 4850, hopefully they will have solved that problem. And the idle power. From what i remember nvidias idle power was much better, at least if it's under load you can understand it using a fair bit of power, but when its doing nothing it's just silly. Either way, hopefully it'll shake up the prices a bit!
  10. quake1-rules
    quake1-rules What's a Dremel?
    6 Feb 2009
    FYI the ATI 4870 can be configured to save idle power, it just doesn't do by itself. I save 36watts (my UPS says so) of idle power consumption by dropping my 4870 512MB to 160mhz GPU and 225mhz for the RAM. Core temp drops to 38c doing that with fan at %25.
  11. yanglu
    yanglu Hmm...
    20 Aug 2008
    Its looking like the RV790 won't be a 40nm chip then. I was kinda hoping it would be, that would really put pressure on Nvidia which has only moved to 55nm quite recently.
  12. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
  13. boiled_elephant
    boiled_elephant Merom Celeron 4 lyfe
    14 Jul 2004
    Yeah, me too. I'll bump mine up to crossfire like you when things get sluggish, that'll be enough for me. I'm hoping that after the next couple of years, graphics will hit a platform for a while where the visual improvements become imperceptible and we can lay off buying £900 machines every two damn years...
  14. HourBeforeDawn
    26 Oct 2006
    they probably have a lot of stock
  15. Horizon
    Horizon Dremel Worthy
    30 May 2008
Tags: Add Tags
