News Rumour: Radeon HD 4890 details and photos leaked
Discussion in 'Article Discussion' started by Tim S, 18 Mar 2009.
  1. Tim S
    Tim S OG
    8 Nov 2001
  2. tank_rider
    tank_rider What's a Dremel?
    3 Feb 2005
    A stock speed of 30MHz over the highest overclock bit have managed with a 4870 1GB looks good! I'd be interested to see how close this gets to the GTX285 speed and title as the fastest single GPU solution!
  3. Zero_UK
    Zero_UK What's a Dremel?
    12 Aug 2008
    Wouldn't be surprising if it's real, after all they haven't brought out a card in two weeks :rolleyes:
    probably going to rival GTX 285? just a cheaper option though... causing GTX 285 sales drops by summer?...
  4. Mentai
    Mentai What's a Dremel?
    11 Nov 2007
    If the rumors are true (probable), what do you think the chances are that AMD will retake the crown of fastest single gpu solution?
  5. Bauul
    Bauul Sir Bongaminge
    7 Apr 2007
    It's debatable whether this will top the GTX 285, but what I will bet my bottom dollar on is it will be much cheaper, and with out a doubt much better value bang-for-buck wise.
  6. p3n
    p3n What's a Dremel?
    31 Jan 2002
    Clock speed increments or swapping shader speed for clock/mem speed is ****ing pathetic, just give us the best card you can manufacture you *******s /rant
  7. wyx087
    15 Aug 2007
    highly unlikely this will top fastest single GPU. that's why rumour-vile also have nVidia making GTX275 to compete (note: not gtx290, so slower than gtx280).
    still, impressive clocks, let's see what other manufacturers with third party coolers can do.
  8. DXR_13KE
    DXR_13KE BananaModder
    14 Sep 2005
    no wonder the GPU market is going to s*** land..
  9. [USRF]Obiwan
    [USRF]Obiwan What's a Dremel?
    9 Apr 2003
    Well I can assure that the last screenshot from salland website is real...
  10. Redbeaver
    Redbeaver The Other Red Meat
    15 Feb 2006
    ATI won't beat Nvidia.
    rawr. :p
    ok, just not this time, i guess...
  11. pimonserry
    pimonserry sounds like a party.
    20 Dec 2008
    Sounds like it will be the last of the 4800 series, and probably the best, although typically the top-end of a line has a pointed price premium :(
    So the 4870 may remain the best deal of ATi's lineup.
    But still, I reckon it could give the GTX280 a proper run for it's money now ;)
  12. frontline
    frontline Punish Your Machine
    24 Jun 2007
    4880 to be a single slot revision but running a lot cooler than a 4850 and with higher clock speeds? Now that would be good to see :)
  13. Turbotab
    Turbotab I don't touch type, I tard type
    4 Feb 2009
    I was hoping that the 4890 would retail for around 200 of the Queen's finest, given that a 1GB 4870 can be had for £170. Hopefully that pre-order price is just a conservative guess:(
  14. ricickle
    ricickle Reamer
    27 Mar 2008
    I wonder if there will be a dual gpu version of this
    4890x2
  15. Slyr7.62
    Slyr7.62 «ŚŁÂŶÈŘ»
    14 Dec 2007
    It'll be nice when this helps push down prices of the GTX 280/285 etc. (My GPU might go to someone else & I'd like a small upgrade :D)
Tags: Add Tags
