News RunCore launches InVincible self-destructing SSDs
Discussion in 'Article Discussion' started by brumgrunt, 17 May 2012.
  1. brumgrunt
    brumgrunt What's a Dremel?
    16 Dec 2011
  2. The_Beast
    The_Beast I like wood ಠ_ಠ
    21 Apr 2007
    I just found the drive for my pron
  3. Shirty
    18 Apr 1982
    The top rated comment on that Youtube video gave me an internet chuckle.
  4. longweight
    7 May 2011
    I want one.
  5. mclean007
    mclean007 Officious Bystander
    22 May 2003
    Mr. Glitter, your new paedo-drive has arrived.
  6. Ending Credits
    Ending Credits Bunned
    4 Jan 2008
    I remember when the big chip manufacturers had this function on their CPUs. :D
  7. Kernel
    Kernel Likes cheese
    29 Sep 2003
    Surely with that cable solution, it should work on any SSD or does that just send a signal to a hardwired component on the board
  8. Tangster
    23 May 2009
    That shuttle PC they hooked it up to is very, very close to the edge of the desk.
  9. Gareth Halfacree
    4 Dec 2007
    That's their system for destroying data on spinning drives: repeatedly drop the PC off the edge of the desk...
  10. PureSilver
    PureSilver E-tailer Tailor
    16 Dec 2008
    Looks to me like the only 'custom' bit of this is the wiring - surely if you supplied any SSD with that wiring (which supplies an unsurvivable amount of current) it would be similarly cooked?
  11. Gareth Halfacree
    4 Dec 2007
    Current isn't something "supplied" by a wire, but demanded by a device. You could connect an SSD to a 5000A supply, and it wouldn't do the slightest bit of harm (aside from being woefully inefficient.)
    Putting RunCore's cable onto a typical SSD will do nothing. The InVincible SSD has hardware inside which listens for the press of the killswitch and then demands vast quantities of current to fry the hardware.
  12. 3lusive
    3lusive Minimodder
    5 Feb 2011
    That's awesome. I love niche products.
  13. Guest-23315
    Guest-23315 Guest
    Awesome idea, though I won't be having one.
  14. Ending Credits
    4 Jan 2008
    ...what?
  15. AmEv
    AmEv Meow meow. See yall in 2-ish years!
    6 Apr 2011
    He's just nervous about kids wondering how to turn the computer on, and end up simultaneously pressing BOTH red buttons.
  16. mclean007
    22 May 2003
    He won't be having an awesome idea :D
  17. mclean007
    22 May 2003
    Agreed. You could deliver a large over-VOLTAGE to any SSD and likely brick it by fritzing the control chips and/or power regulation circuitry, but you'd have no guarantee of having killed the NAND. A determined attacker with enough resources and time (e.g. a governmental intelligence agency or a rival big corporation) could theoretically transfer the NAND chips to another device and read their contents.
    You could achieve a more robust solution with fusible links in the NAND circuit design itself, which would mean you'd need to perform some very delicate microcircuit repair surgery to get at the data, and that makes the challenge of recovering the data for even the most well-equipped and skilled attacker somewhere between exceptionally difficult and impossible, but the data would still be there. RunCore appears to have gone further than this by packaging the NAND chips in a device which, when a killswitch condition is detected, draws a current large enough to destroy the chips with heat - it looks like the chip packaging itself is cracked. The flash cells themselves will be destroyed, with no way to recover the data at all, much as if the whole drive had been incinerated.
  18. Ending Credits
    4 Jan 2008
    I was more worried because it seems like half their market has just vanished :D
Tags: Add Tags
