Electronics running a cathode on a battery
Discussion in 'Modding' started by PowNin N00bS, 7 Jun 2006.
  1. PowNin N00bS
    PowNin N00bS What's a Dremel?
    1 Jun 2006
    wuddup all,, i was wondering if anyone knew how to run a cathode on a battery, preferably a non-car battery. i saw a website where a guy put cathodes in his car using a 9.6v r/c car battery. does anyone know how to set this up or an alternate way to run a cathode on a battery? thanx
  2. Nexxo
    23 Oct 2001
    the cathode tube should come with an inverter. If it was made for computer modding this will connect to 12V or sometimes to 5V. Whether this comes from a PSU molex or a battery does not matter.
  3. Spacecowboy92
    Spacecowboy92 Gettin' Lazy
    10 Apr 2006
    You cant run a cathode off a dry battery. In a car or on the mains it would work fine.
  4. Warrior_Rocker
    Warrior_Rocker Holder of the sacred iron
    26 Jun 2005
    As long as you match the input voltage of the inverter for the cathode (little boxy thing your cathode plugs into and has more wires comming off it) You could run it off any number of batteries like AA's D's or larger batteries, just keep in mind that cathodes generally pull a good bit of power, so the runtime isnt going to be alot of you run it off small batteries like AA's
  5. g0th
    g0th What's a Dremel?
    12 Apr 2005
    A typical 300mm CCFL with 12V inverter typically draws about 370mA, FYI.
  6. Starman97
    Starman97 What's a Dremel?
    17 Sep 2003
