Running a Northwood without the heatr spreader
Discussion in 'Hardware' started by Armand Karlsen, 15 Jan 2004.
  1. Armand Karlsen
    Armand Karlsen What's a Dremel?
    13 Jun 2002
    A few months ago, I had a Northwood 1.8GHz system running quite happily at 2.7GHz, but I had to retire it after I botched a mod to the heat spreader and it would no longer make proper contact with the core. Temps were easily 10-15'C too high even after clocking it back down to 1.8GHz. Is it possible to run a PIV with a cooler on the bare core? I'd think I'd need to either use a shim around the core to prevent crushing, or put a spacer on the cooler to make up for the smaller height of the CPU without the spreader.
  2. Kameleon
    Kameleon is watching you...
    29 Apr 2003
    Yes you can, it's no more dangerous than running any Athlon ;) Just remember to clean off all the gunk that Intel have put between the IHS and the core, and then put on some of your own (just over the core, not the rest of the chip). You'll probably lose a few degrees in core temp too, without the slight insulating effect of the IHS. I hear they're a bitch to get off, though.
    As for the shim/spacer idea, shims are never a good idea IMO. It's very hard to get the distance right, and if you're not spot-on it either makes no difference to the crushability of the core, or prevents proper contact. As long as the springs on the clip for the HSF aren't too weak, the small difference in height with the IHS off shouldn't make a difference. As I remember, P4 3.0 and 3.2s are actually a little bit taller than the lower-specced chips (or maybe they just felt bigger :D) so it should be fine.
  3. Mister_Tad
    27 Dec 2002
    possible? yes
    recommended? no
    the core of a northwood is VERY delicate, this is normally not a problem because it is under the heatspreader, but with no heatspreader it wont take much to kill it or crush it, even the pressure of a heatsink may be enough to kill it
    edit: beat me to it
  4. Kameleon
    29 Apr 2003
    My opinion is slightly different, though ;)
    From what I've heard, the main problem is actually getting the thing off in the first place, after that as long as you don't put the HSF on at an angle there's not that much risk of crushing.
    EDIT - It's gotta be a better idea than running with an improperly attached IHS, surely?
  5. sinizterguy
    sinizterguy Dark & Sinizter
    25 Jul 2002
    Intel mobile processors are examples of Intel processors without heatspreaders. Their cores are fine... and the NW ones are no more delicate than that.
    If you do search around different forums, you will see that there used to be quite a few people running them without the heatspreaders, and this usually allowed them to get better temps and overclocking results too.
    Even the Intel retail heatsink can be used on the processor without the heatspreader and it makes adequate contact with the bare core to keep temps normal ... if not lower than before.
    Use your judgement.
    I wouldnt recommend running the bare core under a Zalman heatsink that weight close to 750g ... that might be pushing your luck a bit.
  6. Mister_Tad
    27 Dec 2002
    i know someone that whipped a heatspreade off a P4 2GHz and it was really delicate and he mashed it putting on the stock hsf
    although maybe that was a williamette and not a northwood
    but either way, it was toast
  7. Kameleon
    29 Apr 2003
    Did he, perchance, sit on said CPU first? :D
  8. Mister_Tad
    27 Dec 2002
    no telling
    although i wouldnt be surprised, hes an idiot :D
    yes the 2GHz cpu was around £500 at the time :hehe:
  9. Armand Karlsen
    13 Jun 2002
    The thing is, I want to overclock the CPU again. I don't think the stock Intel cooler will let me go very far. The only other cooler I've got is a monster Swiftech MCX-4000, with the through-the-motherboard bolt monting system - I don't think that system is designed to take different thicknesses of CPU.
  10. 8-BALL
    8-BALL Theory would dictate.....
    6 Nov 2001
    I would suggest asking about this in the procooling.com liquid cooling forum. There are quite a few folks who have carried out this mod.
    8-ball
    EDIT: 1000 posts!!! :clap: :D
  11. Armand Karlsen
    13 Jun 2002
    I've heard about "direct die" waterblocks, but what about air-cooling?
  12. Mister_Tad
    27 Dec 2002
    you mean air cooling without a heatsink?? that is an accident waiting to happen
  13. Fraggster
    Fraggster What's a Dremel?
    30 Dec 2003
    PICS? :eeek: I want to see what a nekkid p4 looks like :baby:
  14. Darv
    Darv Bling!!
    12 Aug 2002
    With a heatsink like that you shouldnt have a problem with the different height CPU. It can be tightened up until it is making the exact right kind of contact you need.
  15. Tim S
    Tim S OG
    8 Nov 2001
    or Xtremesystems.org forums :)
    they're insane over there tho, be warned :D
  16. Armand Karlsen
    13 Jun 2002
    Ye flipping gods no! Direct-die watercooling as in a waterblock that runs the water directly over the CPU die, without any copper/whatever in between.
  17. Armand Karlsen
    13 Jun 2002
    OK then. Now I only have to worry about the weight of the heatsink crushing the core as I lay it on and tighten it.
  18. Mister_Tad
    27 Dec 2002
    it sounded there like you knew there was direct die watercooling but were wondering if you could do it with air, i guess i misunderstood
    that would be rather silly to say the least :duh:
  19. Armand Karlsen
    13 Jun 2002
    http://www.sandpile.org/impl/pics/intel/p4/478fc.jpg is a pic of the s478 PIV without a heat spreader. It's not mine, but I can tell you it's exactly like that. Nothing special.
  20. Tim S
    Tim S OG
    8 Nov 2001
