Other Running Dell U2711 At Full 2560x1440 Resolution
Discussion in 'Hardware' started by gtiboy, 30 Jun 2012.
  1. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    Anyone with the Dell U2711 monitor know how to run this at full resolution?
    I have a GTX 680 graphics card which has two DVI ports, one is a DVI-D duel link and the other is a DVI-I duel link.
    The Dell U2711 comes with a DVI-D cable, so would I need to purchase another cable in order to run it at full resolution?
    Would I need to purchase another DVI-D to DVI-I duel link cable?
    Picture of Asus GTX 680
    Picture of Dell U2711 connectors
  2. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    I would have thought it will run at full res using the one that comes with the monitor.
  3. longweight
    7 May 2011
    It will do indeed.
  4. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    I was under the impression the monitor needed two cables to run horizontal and vertical resolution separately?
    If this is the case why would Dell put two DVI-D duel link connectors on the monitor? likewise with the GTX680 graphics cards?
  5. bdigital
    10 Aug 2010
    Because the monitor can accept input from multiple sources, and the GPU can output to multiple displays.
    My u27 is set up using a single cable that came with it.
  6. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
    Single dvi cable here = 2560 x 1440 :thumb:
  7. bdigital
    10 Aug 2010
    You mean 1x Dual DVI :D
    You cant output 1440p without it being a dual DVI. (i think thats what you meant, im just clarifying)
  8. N17 dizzi
    23 Mar 2011
    :lol:
    You got me before I saw it and had a chance to edit! Just to confuse things I meant a single dual dvi cable :)
  9. Elton
    23 Jan 2009
    Use Displayport! You know you want to. :D
  10. noizdaemon666
    noizdaemon666 I'm Od, Therefore I Pwn
    15 Jun 2010
    As already mentioned you'll only need one dual link DVI cable. It doesn't matter which output on your 680 is used as the dell only accepts digital DVI. You'd still use a digital DVI cable even in the.DVI-I port as you won't need the analogue part of DVI-I.
    Alternatively use displayport which will do the same thing but with less confusing terminology lol
  11. GoodBytes
    20 Jan 2007
    Your monitor also comes with a DisplayPort cable, You can us that if you want to use 10-bit color support as well (now finding content in 10-bit is a whole new story.. but just saying).
    But yes, as everyone mentioned, dual-link DVI is made from 1x DVI plug. Kinda like your graphic card.. it's PCI-E 16x... it doesn't take 16 PCI-E ports.. just 16 times the PCI-E 1x lines. Hence why the PCI-E 2x or 4x plugs on your motherboard are shorter. Well in the case of DVI the plug is the same size, just more pins are used.
  12. Pookeyhead
    30 Jan 2004
    Dual link DV-I cable here, and that's 2560x1600.
    Just use the cable that came with the monitor... you should have no problems.
  13. gtiboy
    gtiboy Minimodder
    25 Apr 2008
    thats good to know then. So the Display port cable supports 10 bit colour? What about DVI-D?
  14. Teelzebub
    27 Nov 2009
    This mine does
  15. GoodBytes
    20 Jan 2007
    Technical it can. But the monitor and your graphic card doesn't support it via DVI, and DVI doesn't have the bandwidth at this reaolution to support it in any case.
    Please note that 10-bit color support may or may not work for you. While it should, as it's part of the specs of all Geforce GTX 200 series and up, the drivers might not. To know, if it's enabled, you really need PhotoShop CS5, configured for 10-bit color support, and a picture made with such color depth.
    http://www.imagescience.com.au/kb/questions/152/10+Bit+Output+Support
