Graphics Running just a crossfire card?
Discussion in 'Hardware' started by veryevil, 25 Jul 2006.
  1. veryevil
    veryevil Minimodder
    14 Aug 2005
    Hey, I was wondering if you can run just the crosfire master card and then in the future upgrade with a normal card to run crossfire or are the crossfire cards only meant to run in the crossfire configuration?
    Cheers
  2. teamtd11
    teamtd11 *Custom User Title*
    31 Aug 2005
    they run perfectly fine by them self. the only thing you have to remember is that they only have 1 video output. so you can only use 1 monitor
  3. veryevil
    veryevil Minimodder
    14 Aug 2005
    Cheers thats a bugger, oh well standard card it is then! Cheers :thumb:
  4. teamtd11
    31 Aug 2005
    well it dose depend what crossfire master you mean. IIRC only the x1900 crossfire master has 1 dvi. the rest have 2
  5. Highland3r
    Highland3r Minimodder
    25 Jul 2003
    Just plug in the Crossfire link cable and use the second output via that...?
  6. veryevil
    veryevil Minimodder
    14 Aug 2005
    Yeah it would be the x1900.
    Another quick question is there any point getting the XTX over the XT if later its going to be run at XT speeds when in crossfire? (iirc the master cards run at XT speeds and slow down the XTX card doesnt it?)
    Cheers
  7. airchie
    airchie What's a Dremel?
    22 Mar 2005
    I'd get a standard XT and just OC it to XTX speeds.
  8. veryevil
    veryevil Minimodder
    14 Aug 2005
    I was thinking that it is going to be water cooled so OCing is deff on the cards
