Electronics Running LEDs from mains
Discussion in 'Modding' started by Parge, 3 Sep 2013.
  1. Parge
    16 Jul 2010
    Hi guys,
    I wanted to put some LEDs in my custom built wardrobe. I have a socket on the inside of the wardrobe (its built into the wall) so wanted to power them using this, with a switch on the inside that I can turn on/off.
    Is there any easy way for me to power these, or will it require some complex home made transformer kinda malarky.
    I can solder!
  2. longweight
    7 May 2011
    No problem at all, what voltage are the LEDs?
  3. Tealc
    Tealc What's a Dremel?
    6 Oct 2010
    In the thread below (on OCUK) I discuss and show a few different ways of powering LEDs including using a wall mains adaptor.
    LEDs are low voltage DC devices and need the AC voltage converted from 240v AC to a more manageable low DC voltage.
  4. Woodspoon
    Woodspoon What's a Dremel?
    10 May 2008
  5. longweight
    7 May 2011
    There shouldn't be any soldering if he has decent LED tape / modules.
  6. Parge
    16 Jul 2010
    Any, I probably need quite bright ones though (god, does that even make a difference to their voltage? I don't know!)
    Thanks for this dude! I'm going to have a read through!
  7. dynamis_dk
    dynamis_dk Grr... Grumpy!!
    23 Nov 2005
    I've done it using a lower powered adapter for a laptop etc. I've got some 5v and 12v output supplies that work fine for something like this. I just put the right resistor in as required and jobs a good one. Depends a little on if your using LED strip etc but I found it the best way with the least work involved so ran with it :p
  8. Atomic
    Atomic Gerwaff
    6 May 2002
    You can just use a mains to USB power adapter, chop the plug off a cheap USB lead and wire the LEDs up to that.
    Most White LEDs are 5v so USB power adapters are perfect :)
  9. Tealc
    6 Oct 2010
    Only USB LED strips will be 5v. A 12v LED strip needs at least 10v. A discrete LED would need 3.5v@20mA.
  10. longweight
    7 May 2011
    I would just buy some LED tape and a 12 or 24V driver.
