Cooling Running my CPU without a fan. Dangerous?
Discussion in 'Hardware' started by Parge, 6 Jan 2011.
Can I run this without a fan?
Poll closed 13 Jan 2011.
  1. Yes, will probably be ok
    9 vote(s)
    29.0%
  2. No, it will almost certainly overheat
    22 vote(s)
    71.0%
  1. Parge
    16 Jul 2010
    Hi guys!
    Right so I'm currently creating a media server. At its core is a Semprom 3000+ which runs at 1.6Ghz.
    It came with a heatsink and a fan attached to the heatsink. Previously the CPU sat at 43C
    Who thinks I can run it without the fan? The case has one 8cm output fan and a vent for air to flow in
    Who thinks it will melt if I run it without a fan?
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    Well - you can try. The worst thing that will happen is that the chip smashes headfirst into the thermal limit and shuts down.
  3. Nealieboyee
    Nealieboyee Packaging Master!
    14 Aug 2009
    What size fan was it?
    Which direction did the fan blow?
  4. Parge
    16 Jul 2010
    It was a 4cm fan, that blew sideways through the heatsink towards the 8cm fan at the back of the computer.
  5. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    If using the stock heatsink without a fan then of course it will overheat. No option on the poll for that ;)
  6. Picky88
    Picky88 What's a Dremel?
    18 Apr 2010
    It may be ok if you "downclock" it, as it will then produce less heat. While its running you could unplug the fan and see what happens to the temps. I think you would need to buy a bigger heatsink.
  7. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    I think it might be ok, it totally depends on how you load it. I did vote that it would overheat but as it is such a small fan at 40mm its not going to be moving that much air anyway. If it dosen't work too hard then i think you should be ok but it will run hot and then probably not last as long.
    Take the advice if it gets too hot underclock it and put a little lower heat overload shutdown thingy temp in the BIOS.
  8. Parge
    16 Jul 2010
    Ok guys! Thanks for the replies! I'm going to find out! Feedback over the weekend!
  9. Ph4ZeD
    Ph4ZeD What's a Dremel?
    22 Jul 2009
    You might think so, but that isn't always the case. I disconnected the fan from my fenrir and prime 95'ed my chip (overclock in sig) and it didn't hit the thermal limit. Peaked out at 94.
  10. Bartaggio
    Bartaggio Minimodder
    3 Apr 2010
    Any other fans in the case for airflow? Vents close (above) the heatsink? if not I doubt it.
  11. Fanatic
    Fanatic Monimidder
    4 Jun 2010
  12. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    Hehe, I am falling back on the numerous older PC's I've been out to repair with stuck fans tbh. Didn't realise it was just a 4cm fan but still reckon it will be borderline, particularly if the 43c op mentions is at idle :p
  13. Phalanx
    Phalanx Needs more dragons and stuff.
    28 Apr 2010
    I ran my i7 920 overclocked to around 3.8GHz without a fan for 2 months before I put 2 x GT 1850's on it. In general use there was never a problem. :) Granted, this is all housed in a FT02 case with the new penetrator fans, which are amazing.
  14. YEHBABY
    YEHBABY RIP Tel
    22 May 2010
    Depends on the air flow of the case.
    You could always try using a fan controller to slow the fan down enough that you can't hear it. But how much cooling it would provide????? You should experiment and see.
  15. IvanIvanovich
    IvanIvanovich будет глотать вашу душу.
    31 Aug 2008
    try it and see, if you get a good heatpipe heatsink thats meant to be used passive you would have a better result.
  16. Parge
    16 Jul 2010
    No, at idle! I have a feeling it might top out and die since the airflow is pretty bad! I've bought a new 4cm fan (the bearings in the old one were gone!) from ebay for £4 but I'm going to run it without to start with, just to see the results!
  17. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    The Fenrir is hardly a stock heatsink though. I fully expect that one to be able to run passively.
  18. Fanatic
    Fanatic Monimidder
    4 Jun 2010
    Good luck! I reckon you will certainly need the fan with 43c idle temps but look forward to your results :D
    Dont forget to post em up :thumb:
  19. bdigital
    bdigital Is re-building his PC again
    10 Aug 2010
    You could stick one of those little voltage tweakers that fit in a back plate. They are cheap and you could turn the fan right down until its no longer audible (but hopefully still doing something!)
  20. Wicked_Sludge
    Wicked_Sludge My eyes! The goggles do nothing!
    15 Aug 2010
    if it were me, id go one of two routes:
    A. remove the CPU fan and create a ducting for the 80mm exhaust fan to pull air directly past the heatsink and out of the case (some people consider this to be "passive" cooling, though i dont).
    B. replace the annoying, buzzy little 40mm fan with something much larger and quieter (youll probably need to create a ducting in this case too). a 120mm fan, run at inaudible speeds, will probably move more air than the 40mm fan at full speed.
