Scratch Build – In Progress Rustic Wall Mounted PC Build - Wood & Copper [COMPLETE!]
Discussion in 'Project Logs' started by ChrisHowell, 31 Aug 2015.
  1. Mockingbird
    Mockingbird What's a Dremel?
    7 Sep 2011
    This is truly excellent.
    I am more than a little envious. Whenever I see these exposed systems I really want one, and this has a fairly unique look done very nicely. Also, you're a local boy (based on that crate) so that gets you extra points.
    I bet lifting it into place was quite a nerve-wracking experience - I imagine with the right (likely custom) cables you could make disconnects at each end of the copper pipes to make placement/removal easier, but I guess if you're not going to be moving it much there's not a lot of reason to go that far.
    What sort of temps do you get? And how's the noise? I worry about exposed electronics and the noise/heat angle with wall mount builds, but don't actually know if I should or if I'm just being a big jessie.
  2. mehehee
    mehehee What's a Dremel?
    10 Sep 2015
    now that's some good looking art!:D
  3. ChrisHowell
    ChrisHowell What's a Dremel?
    29 Aug 2015
    Thanks guys!
    So I played a relatively new game, Dying Light on High settings 1080p for an hour this week to just check that everything was working OK and see how hot and loud it got.
    Graphics card spun up to a low whirrrrr, but I couldn't hear it above the TV.
    Kraken software showed Max GPU temp as 59
    And max CPU was 48
  4. goldstar0011
    goldstar0011 Multimodder
    2 Sep 2007
    Wow! Really like this!
  5. Waynio
    Waynio Relaxing
    20 Aug 2009
  6. ChrisHowell
    29 Aug 2015
    Finishing touches now. At the weekend I cut out the slots in the metal box for the 2 USBs exposed next to the power button.
    I had purchased an Anker USB hub which was now wired into my build
    I used my metal snips to cut away a majority on the supporting bracket so it would fit inside the box and still provide support for the USBs
    I created a wood shelf inside the box for the bracket to sit on and would glue this in when I fixed it to the wall. I also used the metal snips to cut the holes for the USBs. Not a super-neat job, but looked okay after I filed the edges down
    I set the bracket in place inside the box and it went up fairly easily. I'm pleased with the result of the easy access USB slots compared to the alternative!
    Not too bad at all :)
  7. ChrisHowell
    29 Aug 2015
    I spent the week running the PC to make sure everything was working okay and doing some final touch ups. I sprayed the grey ribbon on the PCIe riser to give it a copper accent and complete the look.
    I'd also had 1 BSOD reboot which was odd, so I decided to create two small brackets to pin the PCIe riser to the wood and away from the back of the graphics card. The riser is shielded but I wanted to make sure this wasn't going to be a common problem. (edit: A week later and several hours played of Dyling Light and the PC has been running fine. :))
    The finished PCIe riser. I liked the standard silver ribbons so I kept them as-is
    I used two thin strips of metal to pin the cable down. Once plugged in, these are mostly hidden behind the cable itself
  8. ModSquid
    ModSquid Modder
    16 Apr 2011
    The pictures have all disappeared...
  9. Waynio
    Waynio Relaxing
    20 Aug 2009
    Works for me & I voted this one in the modding update.
  10. The_Crapman
    The_Crapman Don't phone it's just for fun. Lover of bit-tech
    5 Dec 2011
    Superb. Seen a few good wall mounts but this is has to be my favourite. Love the power botton, maybe you could put in a reset switch that works off a fire alarm?
