PSU Rusty caps?
Discussion in 'Hardware' started by DragunovHUN, 20 Feb 2010.
  1. DragunovHUN
    DragunovHUN Modder
    30 Oct 2008
    I have a 480W Tagan EasyCon PSU and as you can imagine it's not new. When i first got it i still had a socket 478 rig, lol.
    So anyways a few weeks ago it became noisy so today i took it apart for cleaning (manufacturer warranty long gone) and i found what appears to be light surface rust on 3 of the smaller capacitors.
    Is that bad?
  2. Burnout21
    Burnout21 Is the daddy!
    9 Sep 2005
    odd, but i wouldn't worry ifs its just surface damage.
  3. Cerberus90
    Cerberus90 Car Spannerer
    23 Apr 2009
    Probably just from moisture in the air, or in the dust.
  4. Nice Guy Mike
    Nice Guy Mike What's a Dremel?
    13 Feb 2010
    Are they rusty, or have you got blown electrolytic capacitors?
    You can tell by the shape of the cylinder - if you clean them off, are the top surfaces flat or deformed upover into a dome shape? If they're flat, they're probably fine - if they're deformed, they've probably blown.
