Case Mod - In Progress RV02 - Stealth Stalker
Discussion in 'Project Logs' started by FlamingWolfman, 23 Aug 2011.
  1. kelvinb
    kelvinb BF3 Username - D0rmarth
    20 Sep 2011
    thats a fair price really, congrats on the excellent work and keeping an eye on this mod going to be something special +1 rep :)
  2. FlamingWolfman
    FlamingWolfman What's a Dremel?
    23 Aug 2011
    Night time photos
    Here are some night time pictures I took. Have a sneak peak of the system.
    My photography skills are not the greatest, so I apologise if the pictures are not up to standard. :worried:
    Lighting used : NZXT braided LED Cable with lighting control panel.
    Few more stuff to finish off. Next up cross fire cable modding and raven logo painting.
    Catch you laters.
  3. FlamingWolfman
    23 Aug 2011
    Thanks buddy :D
  4. driftingphil
    driftingphil What's a Dremel?
    17 May 2009
    as nice as it is i just don't understand the point of custom watercooling this type of case, with the radiator at the bottom it just goes against what the case is all about.
  5. FlamingWolfman
    23 Aug 2011
    UPDATE : Raven Logo painting.
    Could'nt do much this week been busy at work. Had a few hours to spare today so I did what I could with it.
    Tools used.
    Galeria Round - S windosor & newton size 2 Brush
    Acrylic paint - Titanium white for WH Smith
    Nail Polish remover from super drug
    The painted Logo
    It took along time to do this. Almost 2 hours. I did not want to get the paint on the sides and wanted it only on the top of the letters. Most of it went smoothly, only in 2 places my hand slightly slipped and the paint got on the sides. I managed to clean this up using the nail polish remover after completing the whole paint job.
    All I need to do this leave it for about 12 hours and clear cote it. Just to protect it from scratches and to give it a even feel.
    Overall I'm happy with how it turned out. Let me know your views.
    Cheers guys
    lilgoth89 likes this.
  6. FlamingWolfman
    23 Aug 2011
    Well your partially right. I Choose the case because I love the look of the ravens, they simply stand out. But as for the cooling. The GPU's are the only once which need to be cooled by air, I left a single Penetrator fan in there which sits right at the bottom of the GPU's pushing cooling air into it. This is one of the reasons I used a 360 rad. I could have fitted a larger 420 or SR 560 into the case easily. But I went for a 360 so that I can leave a fan which pumps cool air into the system.
    The system temp right now is 27 degrees after running the system all day long with a ambient of 21 in the room. CPU temps and GPU temps I published in a previous post and are all really good. So having the radiator at the bottom really doesn't effect anything even though you are pushing hot air through the case.
  7. lilgoth89
    lilgoth89 Captin Calliope
    12 Mar 2011
    worked out absolutly awesome m8
    + rep
    btw you would need to do some major work on the case to fit a 560RAD, but it would fit
    ( looked into it before ) youd need to take out some of the front ( or back) of the case to fit in
    in fact you could run the watercooling tubes up the rear of the case and...
    hmmm...inspiration...*looks at bank balance*
    nevermind...>_<
  8. FlamingWolfman
    23 Aug 2011
    He he .. thanks dude.. :D
  9. lilgoth89
    12 Mar 2011
    just makes me want to clean mine off and start again...silverstone should really have just done that to begin with...im also tempted to paint the silverstone logo in the side of the top :)
  10. FlamingWolfman
    23 Aug 2011
    I ended up cleaning up the case before I built it, just in case I wanted to do a upgrade later on.
    I did modify the front of the case.
    As you can see in the picture, I should be able to mount the full size 560 Rad :D after I remove the last fan off as well.
    Removing the front drive caddy off was pretty easy. Only about 10 reverts to pop out, and it just drops out. If silver stone had used screws instead we could have removed it off easier. I don't see why they just didn't make it removable to start with.
  11. lilgoth89
    12 Mar 2011
    but you will find that a 560 rad ends up being about 605mm
    Hardware Labs Black Ice® GT Xtreme 560mm Quad Radiator = 153 x 54 x 605mm
    and the main chamber ( back metal plate to the front one ) is about 590mm
    but on top of that you have about 40mm to the front of the plastic at the front of the case
  12. FlamingWolfman
    23 Aug 2011
    OOO I see what you mean. :sigh: Looks like I will have some cutting to do, if I want to do that.
    I think it would be easier to just dump a 480 at the bottom and 120 at the top to get almost the same performance. Any ways my build for this revision is almost done. A year on who knows what will happen. :naughty:
  13. lilgoth89
    12 Mar 2011
    i think it would look awesome to have a 560rad in the base of mine, but my bank balance dissagrees, should give you amazing performace for very little extra work. you could easily add your gpu's to the loop as well :)
  14. FlamingWolfman
    23 Aug 2011
    I know the feeling mate, yea adding the GPU's as well that another 200 quid for the water blocks and the fittings, and the rad onto that and you need totally about 350 quid to do that. Game over dude.
  15. ferret141
    ferret141 Minimodder
    18 Oct 2010
    Just bought an RV02. I would love to see this project but none of the images are loading for me. Is it just me or does everyone else not see them anymore?
  16. lilgoth89
    12 Mar 2011
    i dont see the images either...
  17. KoSoVaR^
    KoSoVaR^ Professional Sleever & Modder
    19 Dec 2010
    i cant see any pictures att all :S
  18. .//TuNdRa
    .//TuNdRa Resident Bulldozer Guru
    12 Feb 2011
    Looks like all the image links are now 404'd, judging by the error page that appears if you enter the URLs to any of the images.
  19. FlamingWolfman
    23 Aug 2011
    Raven RV02 - Fixed Images
    Sorry about the down images, didn't see it until today. Been away for ages and did not login to this forum.
    I'm back now. Will be doing something new soon.
  20. kelvinb
    20 Sep 2011
    nice work, btw which company did the lazer cutting for you ?
