RyansPC .::Updated 11/1/07::. Mini Update
Discussion in 'Project Logs' started by ry@n, 3 Jan 2006.
  1. NoahFuLing
    NoahFuLing What's a Dremel?
    18 Jun 2005
    Lol.
    Phenomenal progress so far. Thought this would turn out to be one of those mods where someone gets halfway through, and settles with some half-assed job, but you proved me wrong! Absolutely spot on! :thumb:
    *EDIT:* Damn, guess I ought to :read: , huh? :blush: Oh, and wootsicles for second page.
  2. ry@n
    ry@n Minimodder
    31 Aug 2005
    Thanks again for all your comments/support.
    Well it was the same here at first tbh, I didn't think we would have modded it to this extent and especially didn't expect to be using so many power tools and car filler :eeek:
  3. ry@n
    ry@n Minimodder
    31 Aug 2005
    Time to make that rear back plate look a bit more attractive,
    Bought a BBQ grill for £2:
    Cut a rectangle hole in the back plate:
    I then straightened/filed/sanded/cleaned it, followed by primer, followed by paint.
    After it had dried we used Araldite to attach a bit of the BBQ grill.
    (more pics of that if the Araldite has dried by tomorrow)
    My dad found me some PVC pipe in his workshop and cut some chunks off for me which are going to be used as case feet:
    then I sanded them nice and smooth:
    Tomorrow I will prime them, spray them black and wrap them in a bit more of that BBQ grill.
    Peace :thumb:
  4. ry@n
    ry@n Minimodder
    31 Aug 2005
    As promised:
    Im now going to look for a bit of that self adhesive chrome trim to finish off the edges ^_^
    After finishing sanding the bits of pipe, I primed them:
    Sprayed them black:
    And did a test fit of the mesh on the fifth foot (spare/practice one):
    All four are now finished and just need attaching to the bottom of the chassis.
  5. Klekkus
    Klekkus What's a Dremel?
    5 Nov 2005
    Cool, great idea with the feet ;)
  6. hellas91
    hellas91 What's a Dremel?
    18 Feb 2006
    Nice mod guy!! :rock:
    I want to see it finished! :D
  7. ry@n
    ry@n Minimodder
    31 Aug 2005
  8. customh
    customh conflagration.
    22 Oct 2005
    Drill holes in the feet where the holes in the mesh are and light them with LED's I say.
  9. Jipa
    5 Feb 2004
    Those feet really rock :) Maybe drill holes throught the pipe and lit them?
    EDIT: oopsie someone already said it.
  10. ry@n
    ry@n Minimodder
    31 Aug 2005
    My dads already thought of that but im not too sure about lighting the floor, I want to try and keep the lighting pretty subtle but good idea none the less.
  11. mattthegamer463
    26 Nov 2004
    Yes, definitely light them up, that would make them super cool.
  12. customh
    22 Oct 2005
    One per foot LED would be subtle enough, not?
  13. ry@n
    ry@n Minimodder
    31 Aug 2005
    Not had much time recently and all we have done this week is make a perspecs bottom for the case:
    This will have 2X12" CCFLs on top to light up the bottom of the case, this will then have the checkerplate put back to form a cavity which will be used to hide a load of cables later on. :cool:
  14. ry@n
    ry@n Minimodder
    31 Aug 2005
    Bought a few parts from Maplin:
    A keyswitch, heat shrink, rubber grommets and 2 push-to-make switches.
    Also took a trip to the car recycle centre:
    Found a newer version of the volt meter i was going to use which looks better.
    and a vent to use on the top of the case for the exhaust fan (Nissan Bluebird)
    First wave of filler before sanding.
  15. Bullitdodger
    Bullitdodger If it ain't broke....Tweak it.
    9 Oct 2005
    The mod is coming along nicely. :dremel:
    I was wondrering if the vents is meant for a bathroom and if they're easy to get.
    Now, about those feet....Hmmmmm, I decided against them. I don't like them. :nono:
  16. ry@n
    ry@n Minimodder
    31 Aug 2005
    No, the vents are from A Nissan Bluebird.
  17. ry@n
    ry@n Minimodder
    31 Aug 2005
    Today we continued work with the top vent (sorry for the turd photo):
    Made a new switch plate from brushed alloy for the switches I bought from maplin:
  18. ry@n
    ry@n Minimodder
    31 Aug 2005
    Latest stage of the top vent:
    Should be finished by next weekend *crosses fingers*
  19. FaiNT`
    FaiNT` What's a Dremel?
    1 Sep 2005
    That top vent is looking awesome, great work.
  20. ry@n
    ry@n Minimodder
    31 Aug 2005
    Nothing exciting, all ive done this weekend is continue with the wiring of the switch panel and all the CCFLs:
    But sadly, one of the inverters made a high pitches noise and burnt out and on closer inspection we found out what happened:
    :duh:
