RyansPC .::Updated 11/1/07::. Mini Update
Discussion in 'Project Logs' started by ry@n, 3 Jan 2006.
  1. ry@n
    ry@n Minimodder
    31 Aug 2005
    Over two months since my last update! but I should hopefully be able to post plenty in the next couple of weeks pretty much following the completion of this project (apart from the components of course).
    All we have done today is cut the new panel for the new set of switches and paint it blue.
    It will now hold a key switch, vandal resistant switch, 5 toggles and 5 leds.
    More updates tomorrow...
  2. JAxen
    JAxen What's a Dremel?
    18 Nov 2005
    Cool, what will the keyswitch be for?
  3. andyl33t
    andyl33t What's a Dremel?
    20 Jun 2005
    What brand of bondo did you use? Is it very hard once it dries?
    Thanks
  4. ry@n
    ry@n Minimodder
    31 Aug 2005
    The keyswitch will need to be in the ON position before you can press the power button, kinda silly but it looks pretty cool.
  5. calib3r
    calib3r What's a Dremel?
    11 Jul 2006
    Keep up the good work. :thumb:
  6. ry@n
    ry@n Minimodder
    31 Aug 2005
    Thanks for your kind comments :)
    The panel sprayed:
    Most of the switches installed:
    All it needs now is anothe little washer behind the fifth toggle switch and the five panel mounted LEDs.
  7. Lazlow
    Lazlow I have a dremel.
    8 Aug 2003
    Looking great - one question (don't think it's been answered already), is that lock-switch (key) going to turn the PC on? Where did you get it?
  8. Springs
    Springs Boing boing
    29 Aug 2004
    you can get them from maplins..
  9. Jipa
    5 Feb 2004
    Key switches are a standard item in any shop that sell electronic components. I've also managed to find few from old servers...
  10. ry@n
    ry@n Minimodder
    31 Aug 2005
    Scroll up slightly :D
  11. Lazlow
    8 Aug 2003
    I must be extremely blind! Thanks for the info.
    Eta for completion? It's coming along very nicely.
  12. ry@n
    ry@n Minimodder
    31 Aug 2005
    Not that much left to do really, It should be complete before christmas as I will be buying all the components just after.
    To do:
    1.Drill new holes for the new switch panel
    2.Fit the 5 LEDS
    3.Hours of soldering
    4.Stealth mod new optical drive
    5.Drill the new holes for the motherboard stand offs (may not be needed)
  13. customh
    customh conflagration.
    22 Oct 2005
    Beautiful!! Can't wait for FIN!!
  14. JAxen
    18 Nov 2005
    Tought so..
    I have always liked the idea of havin a keyswitch ON before able to turn on the comp :) I cant deside if I will use a keyswitch or not aswell..
    Still, looks super!
  15. mattthegamer463
    26 Nov 2004
    Hey, I was wondering if you could write a guide on how to do that bondo work you did around the vent and the front fans, because its amazing and I want to do some similar stuff on my next project. Alternatively, do you know of any guides on how to do that kind of stuff? Thanks for the help, keep up the good work! :thumb:
  16. ry@n
    ry@n Minimodder
    31 Aug 2005
    I have left plenty of cable sticking out ready for the LEDs when I eventually find reasonably priced ones.
    Quick video clip
  17. itsjustacompaq
    itsjustacompaq Minimodder
    7 Sep 2006
    it looks very cool man. are you almost done aside from the LED's or do you have more plans?
  18. Tulatin
    Tulatin The Froggy Poster
    16 Oct 2003
  19. thedragon7786
    thedragon7786 What's a Dremel?
    18 May 2006
    good suggestion, and GREAT PAINT!!
  20. Ener
    Ener What's a Dremel?
    17 Oct 2005
    lol those key switches are awsome, they kinda lock the computer on/off im gonna rip one from my old amd100mhz system :p
    havent seen this project before, i like it looks good. Cd drives = pain lol for me anyway
