CPU Ryzen 5 2600 & R7 2700X Benchmarks leaked
Discussion in 'Hardware' started by true_gamer, 20 Feb 2018.
  1. adidan
    adidan Avatar is back out of season.
    25 Mar 2009
    This is already confusing. Is Ryzen 2 officially the 3000 series (as in Zen 2) or is Ryzen 2 the 2000 series (the Ryzen Zen1+).
    Mee confooozed. :confused::eek::)
    The globalfoundaries comments we re Zen2 just to be clear :)
  2. Anfield
    Anfield Well-Known Member
    15 Jan 2010
    Yeah, kind of silly of AMD to already go to 2xxx now despite it only being Zen 1.
    Just to avoid any confusion:
    Ryzen 1 (Zen 1) = 1xxx
    Ryzen Refresh (refined version of Zen 1) = 2xxx
    Ryzen 2 (Zen 2) = Presumably 3xxx
    MLyons and adidan like this.
  3. adidan
    25 Mar 2009
    That's how I figured it :)
  4. Guest-16
    Guest-16 Guest
    No, they suggested 7nm was good for 5GHz. People extrapolated from there.
    adidan and TheMadDutchDude like this.
  5. tristanperry
    tristanperry Active Member
    22 May 2010
    So you're saying 7nm will actually be good for more than 5GHz, aka you're saying at least 7GHz?!?
    MLyons and Guest-16 like this.
  6. Guest-16
    Guest-16 Guest
    Precisely. And it'll only be 30W for an 8 core processor.
    tristanperry likes this.
  7. djlegend
    djlegend New Member
    9 Jun 2015
    Why doesn't AMD want to release the 2800X model?
  8. Vault-Tec
    30 Aug 2015
    *tinfoil hat*. Either they are not going to bother** or they are still refining the clocks..
    **TBH I would not even bother with a 2800x. The 1800x wasn't wildly popular most of the Ryzen I saw people buying were 1700 and 1700x. Even as a complete noob on the tech I was able to OC my mate's by proxy (he's in the USA) in about five minutes and his 1700 did an easy 3.9ghz.
  9. djlegend
    djlegend New Member
    9 Jun 2015
    I understand. AMD could get the CPU out later, once it sees what moves Intel will do.
  10. RedFlames
    23 Apr 2009
    The 1800x offered little over the 1700[x], and anyone wanting more than what a 1700/2700 can offer will likely be eyeing up threadripper anyway...
    Vault-Tec likes this.
  11. TheMadDutchDude
    23 Aug 2013
    Exactly that... having three in the original plan was a stupid idea.
  12. Vault-Tec
    30 Aug 2015
    It wasn't really the CPU that didn't make any sense, just the price lol.
  13. TheMadDutchDude
    23 Aug 2013
    Especially when you consider that they all had the same hard limit of around 4 GHz. xD
  14. Anfield
    15 Jan 2010
    Indeed, 1800x was worth a £10 premium over the 1700 tops.
    Of course some idiots like me ordered an 1800x before reviews hit in hopes of a bit of extra oc headroom, but logic dictates that 1800x sales must have fallen off an absolute cliff in favour of the 1700 once reviews hit.
  15. sandys
    sandys Well-Known Member
    26 Mar 2006
    There would have been plenty of people not interested in an overclock.
    The 1800x had a 200Mhz extra base and boost clock advantage over the 1700x, you could just drop it in and you'd have the fastest Ryzen, there were many people with 1700s that didn't hit 4Ghz.
    For those that don't overclock the 1700 was very slow due to it base clock being ~ 600Mhz slower than a 1800x at full load making the 1800x worth every penny.
    Similar reason I bought the 1900x, because it was the fastest clocked Ryzen you could buy all core 3.9 out of the box no overclocking, I didn't need all the cores of the bigger chips, 1900x was already 8 threads more than I had ever owned with loads of PCIe
    The most interesting thing about the new chips is not the max clockspeed its what they manage to maintain under load with the new precision boost and xfr, how it works in gen1 is pretty lame with 1c/2t able to max boost but dropping down to base with 3 threads in use, TR only marginally better with 2c/4t due to its split core make up.
    Guest-16 likes this.
  16. Guest-16
    Guest-16 Guest
    Yea, they needed to be more granular. If Windows decides to target several cores on/off you want it peaking frequency not all going to low clock because they're "active"
  17. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    I'm still a little puzzled with Ryzen and max clocks - the LN2 results show the architecture CAN do 5Ghz+, but the scaling between that and stock/air cooling just doesn't exist. It doesn't seem to matter how big of a radiator you have or how close to ambient your delta is, no Ryzen chip is going to go higher than it would on high end air cooler or AIO unit.
    I hope the 2-series can add a bit of flexibility between 4 and 5Ghz for those that have some serious watercooling hardware, but I suspect Zen 2 will be required for that.
  18. TheMadDutchDude
    23 Aug 2013
    CPUs scale very, very differently with extreme cold. That’s why.
  19. tristanperry
    22 May 2010
  20. MLyons
    MLyons Half dev, Half doge. Staff Administrator Super Moderator Moderator
    3 Mar 2017
