CPU Ryzen 5000 set to bury Intel.
Discussion in 'Hardware' started by Vault-Tec, 29 Sep 2020.
  1. Vault-Tec
    30 Aug 2015
  2. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I'll believe it when I see it in the wild.
    I'll be enthusiastic about it when I see a price on motherboards and RAM, on the proviso that they don't break the bank.
    Bloody_Pete likes this.
  3. David
    7 Apr 2009
    Um, 5000 series are mobile chips, right?
  4. liratheal
    20 Nov 2005
    I thought the 4000 series was mobile, and 5000 was desktop?
    Although I've not looked hard.
  5. rollo
    rollo Modder
    16 May 2008
    Intel CPU still has better average frame rate which surely matters more than theoritical maximum ?
    And can we see some games people actually still play as lets be honest Ashes is 4 years old at this point.
  6. Vault-Tec
    30 Aug 2015
    Desktop. The 5800x is the replacement for the 3800x.
  7. Vault-Tec
    30 Aug 2015
    X570 and B550 are the motherboards?
  8. David
    7 Apr 2009
    So what happened to the 4000 series?
    I swear I read the 4000 were desktop parts and the 5000 were laptop/mobile.
    It doesn't take a lot to confuse me, I know, but I am definitely confused.
  9. sandys
    sandys Multimodder
    26 Mar 2006
    They changed naming I think to reduce the confusion with what was happening between mobile and desktop with mobile being a architecture gen behind, so mobile is 4k, and with 5k I think they will both be aligned.
    Arboreal and David like this.
  10. sandys
    sandys Multimodder
    26 Mar 2006
    Not sure sure it will stomp Intel, in that benchmark I used to be quicker than most reviewed Intel chips at the time with a tweaked gen1 Ryzen, so wouldn't read too much into that.
    My gen1 Ryzen was nowhere near the Intel chips in reality.
  11. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    AMD have decided to use 4000 for laptop & OEM chips, 5000 for retail desktop.
    David likes this.
  12. wyx087
    15 Aug 2007
    I can't wait to grab someone else's 5900x when they upgrade to the next best thing. The rumoured IPC improvement will be great over Zen 2.
    I did something similar years ago, went i5 2400 first, then got a cheap i7 2700k when Intel 4000 series came out and people upgraded to that.
  13. Vault-Tec
    30 Aug 2015
    20% higher IPC than the 3000 series and clocks of 4.8ghz on all cores.
    I'd say that looks like a pretty big nail tbh.
  14. sandys
    sandys Multimodder
    26 Mar 2006
    I'll wait for the reviews, each release of Ryzen has been full of hype that AMD has never met, just tech tubers getting excited typically.
    Its also fair to say that Intel do have 11th gen in laptops that stomps Desktop Ryzen by about 15-20%, so its not a stretch for Intel to release something when needed, remember its not like you need to be able to buy it after announcing/releasing these days :D
  15. Guest-44432
    Guest-44432 Guest
    I've read lots of leaks over the past few days.
    I hope AMD can really come good with the 5xxx series and Big Navi.
    I'll be looking to buy a 5900x if rumors are to be true.
  16. liratheal
    20 Nov 2005
    Wasn't there a whole host of BS about that, though? Like, to support the next round of chips the BIOS needs to be able to support 32mb something or other, but most can't actually do that right now, so although some manufacturers offer the BIOS update, it's on you if it goes tits up and it can potentially brick the board?
  17. Vault-Tec
    30 Aug 2015
    No that was about X470 and prior boards and B450 etc. It had nothing to do with 500 boards fella.
    liratheal likes this.
  18. Spraduke
    Spraduke Lurker
    23 Sep 2009
    Yep should be plug and play on X570 and B550 following a routine bios update. B450 owners would have to do some bios voodoo that is non reversible with a reasonable risk of bricking said board.
  19. liratheal
    20 Nov 2005
    Ah. All I really recall was the drama whenever it was.
  20. Guest-44432
    Guest-44432 Guest
    From what I've also read, Zen 4 AM5 socket will be compatible with DDR5, so it will look like anyone buying an X670 or B650 board for Zen 3 will only get a single CPU use out of the new motherboards.
