CPU Ryzen 5000 set to bury Intel.
Discussion in 'Hardware' started by Vault-Tec, 29 Sep 2020.
  1. liratheal
    liratheal Sharing is Caring
    20 Nov 2005
    I mean.. At this point, three or four generations on one socket is pretty good going.
    I quite liked being able to throw the 3600 in without batting an eye (well, aside from removing the monoblock in a hard line build...) and carry on.
    If the same commitment is made by AMD to AM5, if it's called that in the end, I'd be happy to buy into that ecosystem when the time comes too.
    adidan and Bloody_Pete like this.
  2. andrew8200m
    andrew8200m Modder
    4 May 2009
    Hmmm... 5900x is on the cards for me with a 3080 as and when I can get one. If the 5900x is going to over big boosts over an 8700k in games I'll just stick with a titanxp for the time being and go about sorting myself half a build in the coming weeks.
    It also means I can just get a board and CPU reusing my AIO temporarily, not bother with RAM and GPU and sit with that until the 3080 stock resolves itself so I can go full water-cooling. At which point I'll not need to upgrade again for 3 years or so. Works for me nicely actually :)
  3. thewelshbrummie
    thewelshbrummie Minimodder
    29 Aug 2009
    We'll believe it when we see independent results over multiple benchmarks - and when they're done on the same day and not 4 months apart.
    It's also a cop out that the AMD bench has double the RAM, so it's anything but a fair test and that's before we consider the lack frequency information (like whether the Intel chip was overclocked or running at just base - that leak has nothing to clarify what the settings were).
    Ryzen 4000 APUs exist but are Zen 2, same as Ryzen 3000 CPUs. Ryzen 3000 APUs are Zen+ and a gen behind - which is far more confusing. I assume that the 4000 series name is being skipped for CPUs so that they can sync all Zen3 CPUs and APUs under the Ryzen 5000 brand.
  4. Paradigm Shifter
    10 May 2006
    It would be nice to see a 20% IPC hike, even if clock speeds remain similar.
  5. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    I will be highly surprised if we see a 20% IPC time! Thats a huge reduction for something thats becoming harder and harder to manage. Its like saying they'll be running at nearly 5.7GHz effectively, which seems dubious at best and laughable at worst...
  6. Vault-Tec
    30 Aug 2015
    Facts are starting to emerge as to why the huge IPC hike. And it makes perfect logical sense.
    Latency is down due to one piece of 32mb cache rather than two 16. Instead of a single core having to share cache between two CCX it's now one CCX on one CCD with full access to the full 32mb cache.
    Latency has been AMD's biggest enemy. It's only a huge problem in gaming of course, as things like Cinebench don't care.
    https://forum.overclock3d.net/showthread.php?p=1027411#post1027411
  7. fix-the-spade
    fix-the-spade Multimodder
    4 Jul 2011
    That would make sense, but that would also require AMD to do some consistent and logical branding, which is the one area they have always matched Intel.
  8. Pookeyhead
    30 Jan 2004
    If you only build a PC for gaming, sure. For anyone else who also does other productivity stuff, then Ryzen is the go to choice.
  9. sandys
    sandys Multimodder
    26 Mar 2006
    A 10600k/10900k does not exactly suck at productivity, particularly when all those cores active can often run a lot faster than Ryzen at full load, quite a lot of software doesn't know what to do with 12 threads never mind 20.
    Bloody_Pete likes this.
  10. Gareth Halfacree
    4 Dec 2007
    I'm still eyeing up a 16C32T upgrade. I do a fair bit of bulk processing, and that parallelises *really* well - like, it's 8.5 times faster running as 16 workers on my 8C16T CPU than running a single worker, even when the processing software has its own native multithreading.
  11. sandys
    sandys Multimodder
    26 Mar 2006
    For sure there are cases just making the point that Intel chips don't suck balls at productivity because they have 2 less cores at a similar pricepoint, productivity being a very broad term that sweeps up all sorts of applications, there are still cases where 20 faster threads will trump 24 slower threads, so you need to know your workload.
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
  13. Gareth Halfacree
    4 Dec 2007
  14. Anfield
    Anfield Multimodder
    15 Jan 2010
    Yep they are certainly late to that game, but also inevitable that they eventually came around to the idea.
  15. Paradigm Shifter
    10 May 2006
    That's great for mobile devices, or desktops which are basically just a glorified browser terminal, but mixing cores ends up being a collosal headache for more demanding stuff. Core hopping is still massively expensive, so schedulers will need to become an order of magnitude better at sorting out what goes where, and OSes will need to obey either program demands for running on a specific core and/or obey the user specifying the same. Behaviour of Linux on big.LITTLE arches (like in the ODROID XU4) has not endeared me toward the idea of it for x86. As I said, great for mobile devices where every mW counts, but otherwise?
  16. Guest-44432
    Guest-44432 Guest
    So today is the day. 12PM Eastern time, or to us in the UK 5PM.
    Who else is excited and looking to start a new build with Zen 3?
    Premieres here at 5PM UK:
  17. Aytos
    Aytos Minimodder
    9 Aug 2020
    I'm pretty sure it won't be live, since this is pre-recorded event.
    Guest-44432 likes this.
  18. Guest-44432
    Guest-44432 Guest
    Premieres :winking:
  19. sandys
    sandys Multimodder
    26 Mar 2006
    I'm interested in the performance, doubt I'll do a buy though, I'm full of NVMe and the platform can't handle it, GPU is where I'll be getting my performance gains this year, my CPU typically spends its time waiting for that most of the time anyway.
  20. Guest-44432
    Guest-44432 Guest
    I guess that will depend on how many PCIe lanes the CPU and new Chipset has, if there is an X670 coming.
    Current Gen has 20+4 Gen 4.0.
    But with PCIe 4.0, running a 3080 at x8 lanes will not effect the performance, so therefore, you could run 6x NVMe PCIe 3.0 x4 drives with current x570 and 3xxx series CPU's.
