CPU Ryzen benchmark
Discussion in 'Hardware' started by Vault-Tec, 6 Feb 2017.
  1. Gareth Halfacree
    4 Dec 2007
    But you can't buy it at retail, which means that from the perspective of someone buying an AM4 mITX board it may as well not exist.
  2. Vault-Tec
    30 Aug 2015
  3. N17 dizzi
    N17 dizzi Multimodder
    23 Mar 2011
  4. Vault-Tec
    30 Aug 2015
    Yup. I think my 3.2ghz Ivy scores about 14000 in Physics in Firestrike.
    http://www.3dmark.com/3dm/17973935?
    Aye, pretty much 14k on the nose. So 17+ is very impressive. That was about what I used to score (mid 16s) with a 3970x overclocked to 4.9ghz.
    Everything seems to be adding up nicely to the Broadwell E sort of range.
  5. N17 dizzi
    23 Mar 2011
    With lower platform costs.
  6. Vault-Tec
    30 Aug 2015
    Oh yeah man by miles and miles :)
    That is what I find very reassuring. If one of my rigs goes poof then I can replace like for like for much less than I would usually have set aside :)
  7. meandmymouth
    meandmymouth Multimodder
    15 Sep 2009
    Things are looking promising for Ryzen, but still no reason for me to upgrade :miffed:
  8. [PUNK] crompers
    [PUNK] crompers Dremedial
    20 May 2008
    I'm itching for new shinies too, maybe Ryzen 2nd gen will be worth it.
    Exciting times though! Really pleased to see AMD putting a shift in
  9. N17 dizzi
    23 Mar 2011
    Well, I can see people ditching their 4 cores for 6 or 8 cores with decent IPC, if its affordable. Equally, some may want to go AMD just out of iterative boredom fatigue, ala the Intel Corporation.
    I admit, I also have a ticket for the hype train.
  10. [PUNK] crompers
    20 May 2008
    I like the idea of 6 cores but for gaming its not necessary at the moment as far as i know? If i was still rendering 3D images I'd be very excited.
  11. meandmymouth
    15 Sep 2009
    I'm sure for many the extra cores will be a worthy upgrade and I'd love to say I'd make use of them on my desktop but sadly not.
    However, if Ryzen supports full virtualization and ECC memory...
  12. Anfield
    Anfield Multimodder
    15 Jan 2010
  13. [PUNK] crompers
    20 May 2008
    See this is it, I'd rather be able to OC further than introduce the heat of extra cores, which leaves me with the quad core options and unfortunately they are not enough of an upgrade to justify from what I'm seeing at the moment.
    Having said all this I may just crack and buy myself new toys.
  14. sandys
    sandys Multimodder
    26 Mar 2006
    Cores in gaming is only getting more prevalent the consoles aren't moving away from low power many threads so niether will gaming. 4 threads is a minimum now.
    Once upon a time you didn't need more than1 core for gaming, blimey back in the day you didn't need an FPU I remember buying on of those as a bolt on upgrade much like a Physx card
  15. N17 dizzi
    23 Mar 2011
    Exactly, and it would move to 6 or more cores if widely available. How do 4 cores over 2 currently stack up in current games?
  16. law99
    law99 Custom User Title
    24 Sep 2009
    Thinking 6 core is a minimum on an upgrade for me also.
    So Ryzen looking promising.
  17. [PUNK] crompers
    20 May 2008
    That's fine and at the point that the benchmarks start showing a marked difference I'll probably want to move over to more cores, at the moment I'm not seeing anything convincing despite the fact we're fairly deep into this console gen. To be honest I was expecting things to move that way myself but so far it doesn't seem to be the case.
    So the best thing to do if things are moving in a multi threaded direction is to wait until its needed and buy the best 6-8 core chip at that time.
    At the moment you may as well buy a quad and clock the nuts off it.
    My 2p
    Also, I remember only needing one core for gaming (used to run an Athlon 3700+, 2GB and a 7600GT)
  18. Gareth Halfacree
    4 Dec 2007
    My first IBM-compatible gaming PC was an 8088 running at 7.17MHz and with 640KB of RAM. Damn kids, get off my eLawn...
  19. LennyRhys
    LennyRhys Fan Fan
    16 May 2011
    Loving the look of the Ryzen package design and branding. RGB coolers... pretty but such a gimmick.
    Are we any clearer on specifically what will be launched on the 28th, or could AMD sneak in the 6-core chips and really create a big ball-ache for Intel?
  20. oasked
    oasked Stuck in (better) mud
    24 Aug 2005
    The leaks are showing that it'll just be the 8 core CPUs at launch:
    - 1800X
    - 1700X
    - 1700
    The 6 core and 4 core variants will follow at some later point.
