CPU Ryzen benchmark
Discussion in 'Hardware' started by Vault-Tec, 6 Feb 2017.
  1. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
    "We're gonna need a bigger heatsink base..."
  2. Anfield
    Anfield Multimodder
    15 Jan 2010
  3. Guest-56605
    Guest-56605 Guest
    :jawdrop: That's a beast!!
    I like it :D
  4. Vault-Tec
    30 Aug 2015
    Yeah me too. TBH I think they both look glorious.
    Noctua are releasing some coolers to fit.
    https://www.overclock3d.net/news/ca...hreadripper_ready_tr4_sp3_ready_cpu_coolers/1
    And likely water blocks etc will follow. Gotta say even though I know I won't be able to afford one of these things it's a waft of lovely mountain clear fresh air.
    PMSL look at the socket. Some one has already stuffed the pins :D
  5. RedFlames
    23 Apr 2009
  6. Anfield
    Anfield Multimodder
    15 Jan 2010
    Not sure on the Taichi, I just love the black and white colour scheme of the X370 Taichi too much.
  7. GeorgeK
    18 Sep 2010
    Finally had a chance to push things a little further today. Got it up to 3.9GHz but with a little bit more voltage than I'd want to run this at 24/7 (1.39V) so dialled it back a little and got things stable at 3.85GHz at 1.35V. Considering the cooling I'm happy with that voltage and the Noctua cooler is keeping things under 70 degrees (more like 68 degrees max) during benches, encoding etc. Prime95 is a bit higher but liveable with (under 75 degrees)
    Some updated benches:
  8. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    Good stuff, George!
  9. Vault-Tec
    30 Aug 2015
    Noice :D heat is not really the enemy with Ryzen, it just seems to crap out around 4ghz.
    Talking of Ryzen.. Any one need some new tiles? :D :D
  10. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    It's okay, that person just has really small hands :jawdrop:
  11. Vault-Tec
    30 Aug 2015
    Yeah didn't I tell you? Jeremy Beadle rose from his grave to make a special appearance at Computex ;)
  12. GeorgeK
    18 Sep 2010
    Yeah - even booting at 4ghz seems to be beyond my chip (or at least beyond the voltage I'm willing to give it right now). I'm sure with better cooling this could easily go further.
    Haha - love the size of that cpu - the first time I saw a picture of the socket I thought 'that's the size of a credit card' and then dismissed that thought and just put it down to the picture. Now I've seen that I'm thinking I was right the first time :D Wonder if it has contactless built in? :lol:
  13. Anfield
    Anfield Multimodder
    15 Jan 2010
    Epyc 2 (or whatever they end up calling the die shrink of server Ryzen) will allegedly go up to 64 physical cores under that very same Aircraft-carrier Heatspreader:D
  14. legoman
    legoman breaker of things
    28 Feb 2010
    Seeing as AsRock have crammed an X299 into ITX, will we see an X399 in the same form factor, you know, because reasons
  15. edzieba
    edzieba Virtual Realist
    14 Jan 2009
    I don't think even ASRock could get around that gargantuan socket.
  16. Vault-Tec
    30 Aug 2015
    I reckon it could be done but it would probably need a 90' board with some phases on and I am not sure Asrock would do that. Asus have, but yeah, Asrock usually like to keep it all on one board.
  17. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    I don't even covfefe... :p
    EDIT: Hexus reporting consumer Vega GPUs to hard launch during SIGGRAPH at the end of July.
  18. Anfield
    Anfield Multimodder
    15 Jan 2010
    I suspect even with a daughterboard for the VRM it would require a proprietary redesign of the cpu retention mechanism and cooler mount to shrink the socket a bit as well as abandoning quad channel memory, possible? I'll go out on a limb and say yes, but going to happen? Nah.
  19. Guest-56605
    Guest-56605 Guest
    I'm running a pre AGESA 1.0.0.6 beta (hence why the memory values aren't detected correctly), I've got my memory dialed in at 14 14 14 28 1T @ 3200MHz which has benched as follows -
    I'm quite chuffed with that seeing as the 1600 is only running at 1.33V 3.9GHz to achieve it.
  20. Guest-56605
    Guest-56605 Guest
    The same memory/OC settings now yield a constant score of 1317/18 in Cinebench R15 also, very very happy with that :D
