CPU Ryzen benchmark
Discussion in 'Hardware' started by Vault-Tec, 6 Feb 2017.
  1. CrapBag
    CrapBag Well-Known Member
    17 Jul 2008
    My score was on 2.78b using a adds another 20-30 seconds on.
  2. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    You'd better remove me from the table then. I used Ubuntu's stable version of 2.77a.
  3. GorgTech
    GorgTech Member
    10 Jan 2017
    Ok, so I´ve been using the "wrong" version too? Ok, I´m going to try 2.78b now.
    Edit: Holy Cow, it´s a difference between day and night...
    The same settings I used for my first benchmark:
    Intel i5 6600k @ 4,5Ghz
    32GB 3000 Mhz RAM @ 2666 Mhz 14-14-14-32
    Now this looks a lot better.
  4. David
    David Take my advice — I’m not using it.
    7 Apr 2009
    As did I, back in the day. :)
    TBH though, when small update can produce that much of a difference, I still question Blender's suitability as a benchmark.
  5. RedFlames
    23 Apr 2009
    Given how varied the results were on my Pentium I'd be inclined to agree. I'd expect some variation, but not that much.
  6. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Shame really - it was fun while it lasted. :lol:
  7. CrapBag
    17 Jul 2008
    In all honesty... its utterly useless.
  8. dinoscothern
    dinoscothern Member
    16 Aug 2010
    Not utterly useless - a learning experience ;) The next time the various elements will be specified more fully.
  9. CrapBag
    17 Jul 2008
    I meant the programme not this thread if there's that big a difference between 2 releases.
  10. dinoscothern
    dinoscothern Member
    16 Aug 2010
    You are right, blender is not really designed to be a benchmark. Also its quite possible that different compiler options (or even a different complier) can give better or worse results. So it was fun, but easy to have an apples versus oranges result.
  11. rollo
    rollo Well-Known Member
    16 May 2008
    Gaming results will make or break ryzen is a honest assessment. As the amount of people who can use 8 cores and 16 thread is very limited.
    It has to match the 6600k equivalent chip across a wide range of games. If it does this AMD have a winner. ( if priced correctly) if not it will be largely ignored, the early leaked screens had it well down on this cpu though in games.
    6600k is quicker than the 6900k they are benching against in all games tested on most websites.
  12. Vault-Tec
    30 Aug 2015
    So nobody tried this?
  13. M2r1o
    M2r1o Member
    1 Dec 2010
    I did try it and got 10,285 as highest over 5 runs on my 6600k.
  14. LennyRhys
    LennyRhys Oink!
    16 May 2011
    Yep I tried CPU Mark as well - at 4.6GHz I get 33,451.
  15. Vault-Tec
    30 Aug 2015
    OK well that seems to be a better indication of performance, providing the bench was real of course.
  16. LennyRhys
    LennyRhys Oink!
    16 May 2011
    What I would really like to see is Geekbench result for Ryzen, which would show single thread performance. Perhaps we should start a third Geekbench thread after Ryzen hits the shelves.
  17. rollo
    16 May 2008
    More interesting in that test is how well it scores vs the old AMD chip. I would of expected more gains in truth. As the 8370 I assume is stock always did show well on this. 15k gain compared to this is low side? Considering the extra cores is less than 2k per thread.
    That old chip scores 3031 points per thread. New chip down at 2479.5. Which compares to the 6600k which is at 2571.2 per thread.
  18. SuperHans123
    SuperHans123 Well-Known Member
    27 Dec 2013
    67.91 for my system.
    Stock i5 6500, DDR3 1866MHX
  19. TheMadDutchDude
    23 Aug 2013
    March 2nd ... *grabs popcorn*
    I'll say no more. ;)
  20. David
    7 Apr 2009
    Sod that! I was rocking three radiators at one point. :lol:
