CPU Ryzen benchmark
Discussion in 'Hardware' started by Vault-Tec, 6 Feb 2017.
  1. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Ah. I must've missed your /s :p
  2. TheMadDutchDude
    23 Aug 2013
    There wasn't one to be fair, but the sentence made sense. :D
    I look forward to the new Ryzen CPUs. I really am hopeful that I can get my hands on an early one to see what they're like.
  3. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  4. sandys
    sandys Well-Known Member
    26 Mar 2006
  5. Wakka
    Wakka Yo, eat this, ya?
    23 Feb 2017
  6. Wakka
    23 Feb 2017
  7. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Just in time for the move to X470/B450 for Pinnacle Ridge...
  8. Vault-Tec
    30 Aug 2015
    It's 1,889 in KR which is about £175. However, that may be pre tax.
  9. IanW
    IanW Grumpy Old Git
    2 Aug 2003
  10. Vault-Tec
    30 Aug 2015
    Yeah it seems they are getting ready for coffee lake :)
  11. Wakka
    23 Feb 2017
    And Zen+!
    I really, REALLY hope they can jump the clocks up with Pinnacle Ridge, they don't even need to touch the IPC, just make it happy at 4.4-4.5Ghz and i'll be all over it.
  12. RedFlames
    23 Apr 2009
    if they're wanting £175 for the b350, i dread to think how much the x370 version will be...
  13. Guest-56605
    Guest-56605 Guest
    In other news, I had some goodies arrive from The States yesterday (care of @mnpctech ) for the revamp of my rig -
    Behold...
    They are absolutely mint!!! :cool: :cool: :cool:
  14. Stanley Tweedle
    Stanley Tweedle NO VR NO PLAY
    3 Apr 2013
    23.92
    Piezen 1700 at 3.925ghz
    16GB at 3400mhz
    Offset overclock dropping vcore down to 1.08 idle.
    Giga Gaming 5 mobo with beta bios.
    My ram can do much better... need to optimise. It's Teamgroup 8-Pack 4000mhz but Piezen very limited at the moment. Only got it booting at 3.6ghz ram once. Was even worse with previous bios (couldn't get ram past 2.9ghz).
  15. yuusou
    yuusou Well-Known Member
    5 Nov 2006
    I'm hoping to sometime in the future join the Ryzen bandwagon.
    I have a question for you Ryzeneers.
    Why do people try to overclock all cores equally?
    Say the R7 1700. Depending on cooling, there's more or less a cap of overclocking at 4GHz across all cores.
    Would it not be possible to set, say, 2 cores to 4.2GHz and the remaining to 3.7 or 3.8GHz?
    Then set affinity to your single or dual-core heavy games?
    Maybe even configure it to overclock dynamically to these speeds based on load, using an aggressive governor (is this a thing on Windows?), same way XFR works?
    I'm having a bit of difficulty explaining my intention, I hope that was clear enough.
  16. sandys
    26 Mar 2006
    At the moment you don't seem to be able to do it independently, the chip itself can do so but there isn't any software control to do so manually.
    It looks like Ryzen Master software is geared up for it but all speeds are synced right now, maybe next version of the chip or software will allow it, with the 1900X I haven't bothered overclocking, 4 threads will XFR boost upto 4.2, all cores do 3.9, the extra bump from OC'ing 3.9 to 4.2 makes very little difference in the grand scheme of things for me due to the heat and voltage required, so I just leave the CPU to its own devices unless benchmarking.
    As a 4K games machine the clocks on my GPUs are more important than the CPU, the CPU just needs to be quick enough to support them, which it is.
  17. Wakka
    23 Feb 2017
    I think the cap is in the silicon, regardless of how many cores you're trying to push. R7 would be an absolute beast if you could clock one CCX to 4.5Ghz and keep the other at stock, but unfortunately the ceiling is the ceiling, whether it's 1, 4 or all 8 cores.
  18. sandys
    26 Mar 2006
    If you use something like status core you will see Ryzen XFR will clock any core over 4Ghz, on R7 it is 2 thread XFR, it could be 2 threads on any core, the chip does it dynamically, it would be nice to have some control of that and I hope that is what comes, Ryzen master looks quite elaborate with all the sliders for them to be synced so I would assume the intention is to give you full control, just hypothesising could just be software bloat :D
    I should try turning half my chip off and see if it goes over 4.2.
  19. alfizzle
    alfizzle Ooh aah just a little bit..
    3 Apr 2013
    Im hoping agesa 1.0.0.7 will allow higher speed ram to work more stable, guess we will find out in November.
    Apparently its a complete rebuild, intended for the new apu's, Fingers crossed for improvements over 1.0.0.6 :D
  20. Ramble
    Ramble Ginger Nut
    5 Dec 2005
    Does anyone have a copy of matlab to benchmark with? I've seen reports which suggest that Ryzen is being horribly hobbled to the extent that a 1700X was twice slower at matrix multiplication than a two-core kaby lake laptop CPU.
    I'd be interested for confirmation and strongly suspect those Intel ***** are up to their old tricks.
