CPU Ryzen benchmark
Discussion in 'Hardware' started by Vault-Tec, 6 Feb 2017.
  1. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    The "G" chips are the long-awaited Ryzen+Vega APUs.
    Also,I read elsewhere that X470 will switch from PCIe2.0 to PCIe3.0 for chipset-connected slots (Useful to me as an Intel Optane 900p SSD owner! :p)
  2. Guest-16
    Guest-16 Guest
    ' bout time
  3. Vault-Tec
    30 Aug 2015
    And they are literally giving Vega away for free with these APUs.
  4. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    FYI - Gigabyte have revealed the first X470 motherboard at CES, their "Aorus Gaming 7 Wifi"
  5. Corky42
    Corky42 Where's walle?
    30 Oct 2012
    Pinch of salt time, but it looks like the first benchmarks of Ryzen+ may have been spotted in the SiSoft database, headline would be a 200Mhz increase over Ryzen.
    EDIT: Link to Sisoft result.
  6. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    Asrock have announced an X399M mATX Threadripper board.
  7. Guest-56605
    Guest-56605 Guest
    Definite pinch of salt methinks, 200MHz increase? Boost or base clock speed??
    Lot's of information missing and things to factor into that equation I feel (cooling type used, voltages, is it OC'd etc etc etc).
  8. Corky42
    30 Oct 2012
    Both boost and base, like you say though plenty of unknowns, it's probably a ES but even so a 200Mhz increase isn't bad IMO.
  9. TheMadDutchDude
    23 Aug 2013
    200 on the base and boost would take the top chip to 4.2 with default boosts. Things are about to get interesting... and my finger is waiting to hit buy when they become available. Come on, April!!!
  10. Guest-56605
    Guest-56605 Guest
    4.4GHz-4.5GHz overclocked and stable is on my wish list for 2018 :thumb:
  11. Vault-Tec
    30 Aug 2015
    So it's 3.8 stock? instead of 3.6?
    I know I may sound very hopeful, but if that isn't overclocked then it may go a bit faster than 4.2.
  12. sandys
    sandys Multimodder
    26 Mar 2006
    Not a great bump from Ryzen+ then, that is only 5%, hopefully more to come, at least the extra 5% that was suggested would be nice, not that I'd upgrade, mine is fast enough.
  13. Guest-56605
    Guest-56605 Guest
    So, after hands on experience binning forty five mixed R5's and R'7's for a corporate client - I'm speculating that Zen+ will need to be able to hold 3.8GHz-3.9GHz at between 1.26V-1.28V (hopefully lower) to even be capable of hitting 4.3GHz-4.4GHz.
    As those of us that own them know, Ryzen's Achilles Heel isn't the heat it produces rather the voltage required to sustain the overclock - some chips will also hit a brick wall at a given point regardless of voltage.
  14. IanW
    IanW Grumpy Old Git
    2 Aug 2003
    That leak is for an "engineering sample". It's possible AMD were somewhat conservative in setting the clock speed.
  15. Vault-Tec
    30 Aug 2015
    Yeah there's that too. Intel's are like 2ghz lol.
  16. Guest-16
    Guest-16 Guest
    Not at this stage if it's a branded part. Possibly they could have more XFR boost to differentiate the X parts and add better value to them? Who knows.. It's looking a bit weaksauce if it's only +200 if I'm honest. You can do that just tweaking the same node. I don't hold out much hope for 4.5
  17. Guest-44432
    Guest-44432 Guest
    I'm itching to upgrade from a 4670K! I was going to go for a 8700K, but seeing that AMD are due to release the Zen+ anytime soon, I quite fancy a change to AMD, and I quite like the idea of 16 threads, as my last chip from them, was an Athlon x2 6400 BE. :)
    So am I right in thinking Ryzen 2800x will be launched next month, and X470 in March/April?
  18. Corky42
    30 Oct 2012
    Going on what AMD says, and from what I've been reading others seem to agree, they're expecting around a 10% increase in IPC from both the increased clocks and other minor tweaks. If that's the case would that put them within sniffing distance of Intel's IPC (Coffee Lake, Kaby Lake?), I can't remember how much that gap is with Ryzen.
  19. bawjaws
    bawjaws Multimodder
    5 Dec 2010
    This doesn't make sense :D Increasing clocks might increase overall performance but it doesn't increase IPC?
    Corky42 likes this.
  20. Corky42
    30 Oct 2012
    Doh. :duh:
    Maybe i meant performance. o_O
    EDIT: Yes sorry, i re-listened to the relevant section of the PCPer podcast and it was performance. :oops:
