Enthoo Primo case AMD Ryzen 2700+ AMD RX Vega 64 GSkill TridentZ 3200 14s 2 x 8GB Asus Prime X470Pro be Quiet Dark Power 11 850W Samsung 950 Pro 500GB nvme (Primary) AMD StoreMI setup consisting of Samsung 970 EVO 250GB and Toshiba X300 4TB + another X300 on the way Cooling as follows: Aquaero 6 Aquacomputer D5 + integrated res XSPC RX V3 360mm EK 240mm (fat one) EK Velocity (AMD Acetal + RGB) EK FC Vega with RGB 10 x Noiseblocker PL2s 3 x Phanteks 140mm Steelseries 7G keyboard Steelseries Sensei mouse Dell UltraSharp 2516D (2K but 99% AdobeRgb for photo work) Until this morning it was running on air but I have way too much watercooling stuff not to feel pressured to use it. Pics tell a thousand words - As was this morning Prevously benched like so: This morning I started stripping it down to throw some bits and bobs at it (Aquaero 6LT, EK Velocity, EK FC Vega RGB, Aquacomputer D5 with res) Rads will be XSPC 360 V3.0 and EK XE240 fitted with Noiseblocker PL2s A bit of a long time EK fan (my Supremacy has seen me though Phenom's, FX's and briefly put on the Ryzen until a leak gave the Mrs an excuse to demand that I go back to aircooling like a normal person. I had the Acetal FC block for the Vega which I never got around to fitting, this morning I upgraded that to the RGB version. Vega64 in old suit next to new suit Strip and clean Faff about with little screws and thermal pads for an hour or so gets you this While searching for something in the attic, I found my original EK block - The original Supreme! EK Rad will sit in the bottom and I have the drainage for the loop plumbed in Basically a 90deg fitting with the tube fed though the rad mount to a tap. Bottom rad in situ Trying out Alphacool fittings this time around, quality seems good and pricing not insane like the Bitspower stuff The Velocity fits in nicely with the Asus Prime colour scheme More to come...
