Scratch Build – In Progress S-K-Y-N-E-T : The Beginning [Update:2011-01-24]
Discussion in 'Project Logs' started by McTw1st, 15 Dec 2010.
  1. McTw1st
    McTw1st Rebirth of S-K-Y-N-E-T
    15 Dec 2010
    Hello!
    im Nicklas "McTw1st" Haglund,
    i thought it would be a good idea to post my build log for S-K-Y-N-E-T : The Beginning here.
    The idea behind this build was initially to build a small LAN friendly system, but it evolved from a home built H50 m-itx build to a dual 360 radiator build, so i never had any plans on going with a super high end m-itx gaming system, but as this build is evolving it looks like its going to be quite high end when im finished.
    i asked different companies about sponsorship to help me out with the economical hit, and i thought it would be all in vain untill i got a reply from AquaTuning sayin they liked my concept and wanted to sponsor the build with what they could, not too long after that i got a reply from a swedish company called djungelapa sayin they wanted to sponsor my build with sleeving for the build, that pretty much brings us up to date, anyway enough blabber bring on the pictures!.
    Sponsors:
    Hardware:
    Intel C2D E8400
    Zotac GF8300-I-E WiFi M-ITX
    2x 2GB Corsair XMS2 DDR2
    MSI HD4830 - 512mb (will be replaced for a GTX460 1GB soon)
    Seagate Barracuda 120GB S-ATA
    OCZ ModXstreme Pro 700W
    Dual Phobya G-Changer 360 Radiators
    Dual 400mm long reservoirs
    6x 120mm Cooler-Master Excalibur fan's
    Zalman ZM-MFC1 Fan Controller
    Iv probobly missed a few parts but feel free to tell me ;)
    Concept Pictures:
    Finalized Concept Pictures:
    As you can see by the concept pictures it will be able to open up each part will open ~15degrees.
    Build Pictures:
    There she be the beute ^^
    WiFi Module on
    Zotac Heatsink. hmm wc anyone?
    Meh i allways throw them away
    Temp Motherboard tray cut out finished, Mounting WC Aswell
    Thats what the loop looks like at the minute.
    BUBBLES! Res. Mounted on top of the outlet on the CPU Block for now,
    Close up!
    iv been doing 3D renderings just to get a feel for the build and finaly happy with the end result so its time to start building! :)
    Colorscheme will be, matte black case, green sleeved clear tubes, red and black cables on the inside.
    Update:2011-01-07 : 3 New render pictures added on page 3, while waiting for parts i thought id do some proper renderings so here u go
    Update:2011-01-11 : Parts from the metal worker and djungelapa has arrived !
    Update:2011-01-12 : Parts from AquaTuning has now arrived!
    Update:2011-01-24 : Drilling begins
    Feel free to give feedback and sub for free eyepr0n ;)
  2. Razer2007
    Razer2007 Building Proxima
    18 Jul 2010
    really unique design. Might be really cool. just resize you pics a bit please. make it like 800X600.
  3. McTw1st
    15 Dec 2010
    They should be resized now although i cant see why they stay the same size as before =/
  4. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    Rotate either the left or right tube so that the ports are symmetrical. That's driving me nuts!
    Looking forward to this.
  5. McTw1st
    15 Dec 2010
    haha ! that will be sorted in the final product, dont worry =)
  6. craigbru
    craigbru Cramming big things in small boxes since 2006
    28 Feb 2008
    Oh man, this is going to be an awesome project!
  7. rowin4kicks
    rowin4kicks a man walked into a bar ...
    5 Feb 2006
    please re-size your pics. My bandwidth hates you!
    Nice sketchup skills btw, and as above rotate the res!!
    Good luck!
  8. McTw1st
    15 Dec 2010
    The ports will be symetrical in the real thing dont worry.
    Small little update: Parts ordered for the frame, still havent decided on what material to use for covers, aluminum or titanium they both costs roughly the same so =/
  9. Achron
    Achron Cad Pro Quo
    28 Nov 2009
    Where in the heck are you getting your material that aluminum costs as much as titanium??? Or titanium is that cheap?!??
  10. McTw1st
    15 Dec 2010
    from a local wholesaler that's a friend of my dad's so discount prices are in effect as well ^^
    its roughly 120dollar difference between the pair, per Square Meter that is.
    example: i will have to pay about 250 for 2x2m aluminum sheaths and 370 for 2x2 sheaths of titanium. (side note thees sheaths are 2mm thick the 3mm is lots more expencive for some reason (almost double the price)
  11. llamafur
    llamafur WaterCooled fool
    27 Jul 2009
    Seems like a lot of stress on that cpu block. Totally bad A$$ design! I need to get back to sff builds. I miss my mini gaming cube pc so much.
  12. Carl97
    Carl97 Sorry, for my bad english.
    7 Jul 2010
    Nice concept!:thumb: I really like
  13. Marcos_Viegas
    Marcos_Viegas Minimodder
    6 May 2010
    Wonderfull idea!!!
    Looks a V8 engine... :lol:
    Congratulations!!!
  14. jrs77
    jrs77 Modder
    17 Feb 2006
    If you get a quote at $60-70 per squaremeter of 2mm aluminium then you're getting ripped off. You shouldn't have to pay more then $30-40 per squaremeter for it. So 2x2m would be $150-160 and not $250.
    That aside... nice concept ;)
  15. LooseNeutral
    LooseNeutral What's a Dremel?
    13 May 2010
    Seriously crazy man... count me in! :D
  16. McTw1st
    15 Dec 2010
    Yeah there is allot of stress on the cpu hence i have a plastic block underneath the CPU holding the tension so the board wont flex, its only temporary thou
    Thx buddy :)
    Counting the fans it would be a v6 ;) tsk tsk
    Hehe i know i only said it as an example :p
    tyvm
    tyvm!
    Side note: apparently due to x-mass so close by the companies that im ordering from seems to take longer than anticipated so hopefully i can start building in the week between x-mass and new years eve
  17. Alexandros
    Alexandros What's a Dremel?
    10 Jan 2010
    Fascinating design, I really like it!
    Just help me out here though. Which Sketchup motherboard are you using? It looks kind of familiar, but I can't really place it. Did you make it yourself?
  18. LooseNeutral
    13 May 2010
    Added bonus to your New Years resolution I would think. With a name like SKYNET you should find plenty of "outside the box" inspiration for the little details, rushing things reduces the possibilities. ( like jrs77's pointing out.... save here and perhaps spend there.... nice powder coat? or whatever) Look forward to this... glad you decided to post a log..... "No Fate..." :D
  19. McTw1st
    15 Dec 2010
    im actualy thinking something along with this blue color
  20. LooseNeutral
    13 May 2010
    Purty! looks a bit like a cobalt blue?
