Scratch Build – In Progress S-K-Y-N-E-T : The Beginning [Update:2011-01-24]
Discussion in 'Project Logs' started by McTw1st, 15 Dec 2010.
  1. Warsmith
    Warsmith Enginseer
    5 Dec 2010
    Paint would flake off when any flexing was done to the tubing. Black tubing would be better.
  2. McTw1st
    McTw1st Rebirth of S-K-Y-N-E-T
    15 Dec 2010
    depends if the tubing will be mounted flat to the surface and wont budge, im gonna test various of things and tubings to get the final look :)
  3. McTw1st
    15 Dec 2010
    another sponsor joins the build.
    this time its a swedish sleeving company called djungelapa.se.
  4. McTw1st
    15 Dec 2010
    Tiny little update:
    AquaTuning delivery on the way (estimated arrival next week)
    djungelapa.se delivery on the way (estimated arrival next week)
    aluminum + steel 1.5mm thick on the way (arrives Wednesday next week)
    Time to put everything together by the end of next week :)
    color scheme decided as well: matte black, red and black sleeving on cables + green sleeving on the tubes with clear coolant.
    Stay tuned ;)
  5. coolamasta
    coolamasta Folding@Home CC Captain 2010/11/12
    26 Apr 2009
    Looks like this will be gooooood, will be watching, good luck bud :D
  6. McTw1st
    15 Dec 2010
    don't know if you want a detailed list on parts on the way but you'll all get it anyway!
    Complete sleeving kit for psu + tubes
    parts for the case few 90degree 10x10mm profiles few 135degree 10x10 profiles, few metal sheaths,
    Watercooling parts list arriving from aquatuning:
    8x 10/8mm (8x1mm) screw-on fitting G1/4 90° revolvable - black nickel
    2x 10/8mm compression fitting 45° revolvable G1/4 – black nickel
    4x 13/10mm (10x1,5mm) screw-on fitting outer thread 1/4 - black nickel plated
    4x 13/10mm (10x1,5mm) straight bulkhead fitting - black nickel
    1x Arctic thermal compound MX-4 Tube 4g
    3x Cooler Master Excalibur
    2x EK Water Blocks EK-Multioption RES X2 - 400 Basic
    1x Phobya G-Changer 360
    1x Zalman Multi Fan Speed Controller ZM-MFC1 Plus black
    reason for the diffrent sized fittings is because i will be running a clear tube that is actually stretchable to 13/10 from 10/8 plus i thought it would look cool if it were thicker fittings on the outside than the inside of the case.
    best regards
    Nicklas "McTw1st" Haglund
  7. McTw1st
    15 Dec 2010
    just cause im waiting for them parts i thought i shuld add thee's pictures to the build, their better renders of the case. and yes the crooked fittings are fixed ;) (alltho their not textured -.-)
  8. McTw1st
    15 Dec 2010
    UPDATE! THE BUILD BEGINS!
    Parts has started to arrive! :D
    Sleeving from Djungelapa has arrived and the parts for the case from metal worker.
    This is what im gonna use the green sleeve for
    Unfortinetly the metal worker got all my angles wrong so he's gonna redo them in the morning.
  9. McTw1st
    15 Dec 2010
    MOAR parts! :D
    AquaTuning parts has arrived
    and i just got a call from a company saying that im starting to work tomoro at 08:00AM
    SO I GOT A FREAKING JOB!! HELL YEAH!
    Now its time to start working on the assembly then paint it and then final assembly ^^
  10. KidMod-Southpaw
    28 Sep 2010
    Well done on the job! Nice parts too.
  11. Kojak
    Kojak Who loves ya baby
    3 May 2010
    Nice gear, roll on the construction mate!! :thumb:
  12. Zanib
    Zanib What's a Dremel?
    6 Jan 2011
    Odd, but i like :)
  13. McTw1st
    15 Dec 2010
    guess what guys, build's started
    although after 1½ holes the battery in the drill died -.-
    so im waiting for it to recharge right now so here's some pics on how far i came
  14. McTw1st
    15 Dec 2010
