S.m.a.r.t
Discussion in 'Hardware' started by Lazy, 2 Jun 2002.
  1. Lazy
    Lazy Meow?
    13 Nov 2001
    just wondering what S.M.A.R.T is for hard drives.
    Anybody know? :idea:
  2. herbs
    herbs Nobody but us chickens
    7 May 2001
    Its used to try and detect wether your hard drive is going to fail.
    S.M.A.R.T = Self-Monitoring Analysis and Reporting Technology ( I had to look that up) you can read more @ http://www.belarc.com/Drive/smart.html
  3. samuelellis
    samuelellis What's a Dremel?
    19 Apr 2002
    god i wish my laptop had had that i may still have my coursework, i think its built into all drives by default now isnt it?
  4. scoob8000
    scoob8000 Wheres my plasma cutter?
    17 Feb 2002
    Yeah its pretty much standard on HD's anymore.. you can get proggies to read the SMART data from the drive.. CPU cool does the trick, but the numbers are about pointless..
    -scoob8000
  5. Lazy
    Lazy Meow?
    13 Nov 2001
    its disabled by default so should i enable it?
  6. jamiesurfs
    jamiesurfs Boom Boom, Cha Cha Cha!
    21 Oct 2001
    You only really need to enable it if you are particularly worried about your hard drives failing as it should give an early warning! However, there is suppossedly a performance hit as it takes a while longer than normal to read data while it checks the drive meaning a slightly slower system! It's remains your choice though.;)
  7. Behemoth
    Behemoth Timelord in training
    1 Nov 2001
    i've kept it enabled ever since many years back that my 2.1 gig hdd crashed big style (2.1 gig was considered entry level back in the day) whilst waiting for a replacement from Quantum (It was Quantum Big Foot if memory serves me correctly) I bought a Western digital 6 gig drive, whic was consdiered obscene!!
  8. LoopyJuice
    LoopyJuice Astronomical
    24 Jun 2001
    /me goes to disable it :)
  9. felix the cat
    felix the cat Spaceman Spiff
    11 Jan 2002
    unless you are running an un cooled IBM 75GPX series hdd, i guess having it not enabled with most modern hdds should be fine....
  10. Fly
    Fly inter arma silent leges
    31 Aug 2001
    heh, IBM reliablity strikes again...
  11. felix the cat
    11 Jan 2002
    muhahahaha....my 60gxp is still runnin fine...
    apart from a bit slooooooowwww as its too filled up....
  12. herbs
    7 May 2001
    Mines starting to play up, and this is my second one. POS.
  13. Lazy
    Lazy Meow?
    13 Nov 2001
    my ibm drive is cooled with a hard drive cooler and an 80mm fan. I overheated it at a lan when it wasn't cooled and now it won't work without a fan :D
  14. felix the cat
    11 Jan 2002
    hmmm...mine used to sit in a globalwin king kong...now it sits freely under two 80mm YS-Tech exausting the hot air out of my case...:D
  15. samuelellis
    19 Apr 2002
    am i the only person who does not have a cooler on his hard drive? im running a fujitsu 20gig (think its only 5400 rpm, cant remember bought it when 20gb was max you could get) but hey it runs cool, never had any problem with it & why would you toch IBM with a stick? im stiking to fujitsu drives & i havent noticed that much of a performace hit with SMART enabled & never noticed on when i switched it on on my friends maxtor high speed drive (agian cat remember what it was) but i think the speed incrase if it is there is minimal at best (doe sit really matter if you drive loads that mp3 0.00000005 seconds faster than before, as long as it does it & is reliable?)
    oh my god i cant belive me the speed freak has just said that
  16. felix the cat
    11 Jan 2002
    any drive that is 7200rpm to 15000rpm it should be cooled...but does not need to be...
  17. LoopyJuice
    24 Jun 2001
    well my Maxtor D740X 40GB never gets warm to the touch even if it's a 7200rpm drive, it is always cold, anyways i have it in a hard drive rack thingy which comes with the Lian-Li cases and it has 2 80mm fans blowing past it all the time :)
  18. IsaacSibson
    IsaacSibson Banned
    15 Nov 2001
    With that kind of airflow over it, it shouldn't get warm at all. My Barracuda II doesn't get at all warm with one 80mm blowing over it (chieftec dragon), and that had a real hot and loud reputation (as well as being the fastest at the time).
  19. LoopyJuice
    24 Jun 2001
    yeah i meant even with no airflow it doesnt get warm :) i have it there because it goes there :)
