Scratch Build – In Progress S.PiC Simple Case mk1
Discussion in 'Project Logs' started by S.PiC, 4 Mar 2019.
  1. S.PiC
    S.PiC Member
    3 Feb 2016
    Good day everyone!)
    There was an idea to create a small case for the mini-itx motherboard, full-size graphics card and ATX power supply. This time the material will be 2mm aluminum cut with a laser.
    Compared to previous projects, the forms are quite simple, hence the name: Simple Case mk1.
    So let's get started!)
  2. S.PiC
    S.PiC Member
    3 Feb 2016
    Personally, case was bent on the bending machine at work) Turned out nice, but got some shoals when you use specific old instrument (bending machine).
  3. DÈF¥âÑt¸.·´¯`¤
    DÈF¥âÑt¸.·´¯`¤ Active Member
    14 Sep 2004
    Damm i gotta get me on them laser cutting machines for the work shop!!!
  4. Cheapskate
    13 May 2007
    SPIC BUILD! :rock:
  5. S.PiC
    S.PiC Member
    3 Feb 2016
    _Prometheus_ likes this.
  6. Cheapskate
    13 May 2007
    I'm shopping too. :lol:
  7. S.PiC
    S.PiC Member
    3 Feb 2016
    Prototype photos:
    Waiting for sponsors parts for final Assembly...
    _Prometheus_, Arboreal and Cheapskate like this.
  8. kim
    kim Active Member
    10 Jan 2016
    it looks fantastic, for what I can see as of now :naughty:
  9. Cheapskate
    13 May 2007
    Lots of nice little details. I like how you crenelated the edges to make the layers more pleasing.
  10. S.PiC
    S.PiC Member
    3 Feb 2016
    I am glad you like it!)
    Thank You so much! Your words are a great praise for me! :dremel:
    More photos of PROTOTYPE:
    Cheapskate, Arboreal and _Prometheus_ like this.
  11. S.PiC
    S.PiC Member
    3 Feb 2016
    New photos:
  12. Cheapskate
    13 May 2007
  13. Arboreal
    Arboreal Well-Known Member
    21 Jan 2011
    E.PiC!! That is a really smooth raw metal build.
    What are the dimensions? I can't scale it easily. I could see an ITX one being really good for my LAN kit.
  14. kim
    kim Active Member
    10 Jan 2016
    :clap::rock:awesome little rig... :eyebrow: just wondering what is the proc and MB and regret that the thread was so short this time :grin:
  15. S.PiC
    S.PiC Member
    3 Feb 2016
    Thank's!) Dimensions without handle, which also acts as a stand, approximately 360mm*310mm*150mm
    Thank you so much!) It's just PROTOTYPE! The final build with sponsor components in the work.
    Now in the prototype is installed: Intel i5 6400 on ASUS H170I-Pro, nVidia GTX 1080ti Founders Edition, Seasonic Prime 650W Titanium. Waiting for sponsorship components. The bottom fans perfectly cool the loaded graphics card.
    Arboreal likes this.
