hmm on the back of my geforce 2mx there is an s-vid input/output, i not sure which but my dvd player has the same output, where can i get a cable to link them? maplins code anyone??
here's the code maplin BV35Q is 3m lenght NZ35Q is 15m length they have other higher quality ones but those are the cheap & chearful ones.
I dont think anything will happen as the s-video hole on the gfx card is output just like the monitor.
My old Voodoo3 3500 had a s-vid out but you could only use one for output at once, but my mates MX can use monitor and s-vid at the same time for dual monitor action
the g force 2mx supports twin view will let you display an identical image on your monitor/tv or let you use multi displays eg split the desktop across the two. note normal TV's will only go up to 800 * 600 resolution. and gf2's aren't the best for DVD output to TV.
hahaha what tvs r u useing hahaha man my grundig tv goes up to 1280-1024 man u must be useing a cruddy tv thats the lounge tv my bedroom tv can handle up to 1024-768 i havent gone higher then that with it but man 800-600 man
