S12II 82-Plus (Bronze Series)
Discussion in 'Tagan / Seasonic / SilverPower' started by Nathan@Nanopoint, 27 May 2009.
  1. Nathan@Nanopoint
    Nathan@Nanopoint Ctrl Alt Del
    2 Feb 2009
    Seasonic Electronics introduces the S12II Bronze Series
    Power supplies that deliver higher efficiency, advanced stability at the right price point.
    Seasonic Electronics launches the S12II “Bronze” Series; the updated version of the award winning S12II Series to meet the growing demand for high efficiency and yet price competitive power supplies. The S12II “Bronze” Series maintains the same power output ranges and as well, the superb quality and super silence of the S12II Series but in addition, higher grade components are used to achieve the 80 PLUS “Bronze” threshold and improved DC cable arrangements to ensure optimal flexibility in usage.
    The S12II Bronze Series achieves the 80 PLUS(R) Bronze standard of at least 82%, 85% & 82% power usage efficiency at 20%, 50% & 100% operating loads respectively. This, combined with Active Power Factor Correction, enables the S12II Bronze to reduce energy waste, boost power efficiency and more importantly, reduce the energy costs for the users.
    In addition to the efficiency upgrade, the S12II Bronze Series maintains the strong foundations of the S12II series. Important features such as the stable and proven Double Forward Converter circuit design, the industry leading Smart and Silent Fan Control (S2FC) and the use of high reliability Japanese brand capacitors are all carried forward to the “Bronze”.
    The S12II Bronze Series, similar to its predecessors, is available in the standard ATX Form Factor and in wattages that are most common for a PC system. In addition to the all-in-one cabling design, the 430W and 500W models come with additional EPS connectors for IPC and server systems and supports both 6P & 8P PCI-E connectors for the most current and high end dual graphic cards.
    The S12II Bronze Series meets most major safety and EMC directives and as well, environmental regulations such as RoHS & WEEE. Special built-in protection features such as Over Voltage Protection (OVP), Over Power Protection (OPP), Short Circuit Protection (SCP), and Over Current Protection (OCP) are also included for added safety and usage reliability.
    80 PLUS(R)is a registered trademark of EcosConsulting
