Graphics s3 virge
Discussion in 'Hardware' started by woof82, 23 Aug 2005.
  1. woof82
    woof82 What's a Dremel?
    18 Jul 2005
    I installed the hardware then booted my computer. I went to the "add hardware" wizard and it claims that "this device cannot start (code 10)".... help! :wallbash:
  2. woof82
    18 Jul 2005
    this guy seemed to sort it out, but I dont know how :(
  3. TMM
    TMM Modder
    12 Jan 2004
  4. woof82
    18 Jul 2005
    I clicked "update hardware" but it "couldnt find a better match" for my hardware... could you suggest to me a good site to download drivers from?
  5. Guest-16
    Guest-16 Guest
  6. woof82
    18 Jul 2005
    Thanks for the link it ended me up here but I dont know where to go from there!?!?
  7. Guest-16
    Guest-16 Guest
    The card is totally unsupported in the 2k/XP kernel, you're stuffed unless you find some enthusiast, 3rd party drivers of which i recon you've got more chance winning the lottery or finding a unicorn.
  8. Godboy_g
    Godboy_g What's a Dremel?
    13 Aug 2004
    Actually I use an S3Virge in my three monitor setup. The problem is that it needs to be set as the primary display in your BIOS. It has something to do with the architecture of the card I think. That was the only way I was able to get it to work.
  9. woof82
    18 Jul 2005
    thanks very much godboy g :)
