Modding S340 elite Rebuild!!! Updated 7/20/2017
Discussion in 'Modding' started by beret21, 15 Jul 2017.
  1. beret21
    beret21 Member
    2 Dec 2016
    Some WHYsss?
    Q. Why put the CF vinyl and then removed it?
    A. When we started the case mod 4-5 months back the case looked a lil too white from inside to use so before assembling it we added a lil more black color to the case.
    Later when it was all assembled we found that the mobo, rad and pump parts being black and the background being black the case got a lil too dark. So that’s why we removed it in this rebuild.
    Q. What is remaining?
    A. The case front will be modded. Two slim fans at front will be added. The loop might change a bit too. A 90 degree USB 3.0 connector. New drive bay plate and might be some more tweaking done. And off course GPU and RAMs will b added if I got em in time :)
    Update 1 7/15/2017
    Update 2 7/20/2017
    Once I have completed the BUILD I will update here.
  2. beret21
    beret21 Member
    2 Dec 2016
  3. proxess
    proxess Active Member
    5 Nov 2006
    That's also how I brush my teeth! White vinegar, chilli sauce, dish washer!
    Will you be putting in Scythe Slip Stream fans in the front?
