Build Advice Sabertooth/i30 HSF check
Discussion in 'Hardware' started by Karrlas, 15 Jul 2012.
  1. Karrlas
    Karrlas Ageing too fast...
    23 Apr 2009
    Just about to pull the trigger on an order to replace my 3yr old PC (can't believe it's that long!) :eeek:
    Just wanted to check that the cooler I'm after, the Artic Cooing i30 will sit ok on the Sabertooth Z77 board, without impacting on the ram slots or other part to any significant degree?
    Tried googling but nothing either way shows up.
    Thx in advance.
    ***Edited thread title, might help if someone searches for same combo.
  2. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    just get low profile ram and you are sure not to get issues.
  3. Karrlas
    23 Apr 2009
    Low profile ram is already in the config, just wanted to be sure.
    This'll be my biggest spend on a rig to date, so just covering the bases :D
  4. RustyTool
    RustyTool What's a Dremel?
    6 May 2012
    I think u won't have any issues as far as u use low profile rams
  5. MSHunter
    MSHunter Minimodder
    24 Apr 2009
    Freezer i30
    looks compatible with socket and with LP ram no issues there either.
  6. lancer778544
    lancer778544 Multimodder
    5 Jan 2011
    Karrlas, have a look at my post here.
  7. Karrlas
    23 Apr 2009
    *Ignore unwanted post*
  8. doyll
    doyll Minimodder
    1 Jul 2011
    Rated for 300w :jawdrop:
    i30 is way over rated.
    There are better coolers for same money
  9. rollo
    rollo Modder
    16 May 2008
    i30 is fine with mensioned motherboard
  10. Karrlas
    23 Apr 2009
    Have found a picture and it would seem there is more play in the distance between the cpu and ram slots, so all would seem good.
    That may possibly be so, but the i30 sits better with the aesthetics I have in mind.
  11. Karrlas
    23 Apr 2009
    Well the build is complete and an awesome machine it is! :rock:
    I can confirm that when the cooler is installed, the fan is over the RAM area, you WILL need low profile variants for it all to fit together!
  12. GeorgeK
    18 Sep 2010
    Not according to this - the only 'better' (albeit much noisier) coolers are basically double the price. It's not the prettiest cooler imaginable given but it certainly seems to do the business for £30
