PSU Safe no of SATA drives off one cable?
Discussion in 'Hardware' started by quirkalfeeg, 21 Nov 2010.
  1. quirkalfeeg
    quirkalfeeg Its a trick...get an axe.
    6 Nov 2010
    Hi (again!)...
    In the quest to finally have a clutter free case I thought I'd ask your advice.
    I'm just tidying the cables on a new build and I'll be running 3 Spinpoint F3's and an optical drive - I also have a Corsair modular HX 850 PSU:
    I thought I would connect two sata power cables to the PSU and connect two drives per cable.
    My question is how many drives can you power off the sata power cables safely?
    http://www.corsair.com/products/hx850/default.aspx
    Thanks...
    Q.
  2. Picarro
    Picarro What's a Dremel?
    9 Jun 2009
    You should be able to power everything of one cable unless your PSU is seriously faulty :)
  3. Krikkit
    21 Jan 2003
    Many times over, in fact. Hard drives draw very little power and an 850W PSU should be able to handle quite a bit on each of the modular bits.
  4. PhoenixTank
    PhoenixTank From The Ashes
    5 May 2010
    Well, each SATA power cable for the HX850 has 4 sata power connectors so... 4. You'd probably be okay to use extensions and such if you had to, though one cable to HDDs and one to the optical bays at the top do it for me.
  5. Cthippo
    Cthippo Can't mod my way out of a paper bag
    7 Aug 2005
    Once upon a time with the old SCSI drives having an array's worth of them spinning up at the same time was an issue, but not any more.
  6. Bloody_Pete
    Bloody_Pete Technophile
    11 Aug 2008
    Off my PSU I think it's in the region of 20-30 HDDs... You's will be fine for 15...
  7. quirkalfeeg
    6 Nov 2010
    Thanks everyone - very helpful as always...:)
  8. Booga
    Booga Cuppa tea anyone?
    28 Sep 2009
    I have an F3, a Vertex 2E and an optical drive off 1 ribbon cable.
  9. Bloody_Pete
    11 Aug 2008
    What does that mean???
  10. Boscoe
    Boscoe Electronics extraordinaire.
    5 Jan 2010
    It depends on how many rails you have (dunno for the HX 850) so if the overall max amount of recommended drives was 30 and had two power rails then you could only have 15 (recommended) on one slot. Although I think yours will be one rail and so only need to use one cable.
  11. Chicken76
    Chicken76 Minimodder
    10 Nov 2009
    A hard drive will usually draw 2A (from the 12v rail) when it spins up (that's only about a couple of seconds, when you turn on the computer) and much less afterwards. So multiply 2A by the number of HDDs you have and then compare with what your PSU can deliver on a single cable.
  12. Booga
    28 Sep 2009
    It means I have 3 drives running off 1 cable with no problems.
    I guess it is not quite as informative as the other posts but I thought it might help.
