I'm hesitant to define this as a "mod," but what is the safest way to switch the keys around on your keyboard? On my old basic PS/2 M$ one, I just popped 'em off with a butter knife, but now I have a shiny new G15. I'm especially concerned about the LED backlights. Ideas?
I moved the shift key and the arrow keys around on my eeePC with the utmost ease using a free app called KeyTweak.
I would say just try prising one off carefully. probably the right windows key as your unlikely to use it, or one of the G keys. Then you can figure out how they are attached and what way is best to get em off.
found this, might help http://techgage.com/viewimg/?img=/reviews/logitech/g15_revised/logitech_g15_revised_24.jpg&desc=Logitech G15 Version 2 looks like the keys are held in by plastic clips.
