Other Safety Razors?
Discussion in 'General' started by glaeken, 20 Dec 2011.
  1. Almightyrastus
    Almightyrastus Rule #9
    21 Mar 2002
    I have to say that is one of the most common things I hear form people when they convert to proper wet shaving.
    They start off with "I hate shaving, it such a chore, always hurts" and nearly always switch straight to "this is so cool, I enjoy shaving now".
  2. Nexxo
    23 Oct 2001
    Yup, I'm one of those. :)
  3. LithiumDesign
    LithiumDesign 3dsMax User
    23 Jul 2009
    got me one of those cheapy wilkinson sword classics about a month ago - getting on brilliantly with it so decided to take the plunge on a Muhle R89, some 7 o'clock blades + free derby blades, proraso cream and a vulfix 404 badger + boar brush
    can't wait for my hair to grow back so I can shave again!
  4. TheBlackSwordsMan
    TheBlackSwordsMan Far over the misty mountains cold
    16 Aug 2009
    Welcome to the Manliness, son.
  5. mars-bar-man
    mars-bar-man Side bewb.
    17 Apr 2009
    Unscrewing my razor to change the blade..
  6. Tichinde
    Tichinde Active Member
    1 Sep 2010
    I did that the other week pulling the top off my Futur.
    Pulling razor blades out of your thumb kinda sucks.
  7. Almightyrastus
    21 Mar 2002
    meh, the gods saw fit to bless you with spares ;)
    Got to spill a little blood to make any manly task worthwhile
  8. TheBlackSwordsMan
    16 Aug 2009
    The sides, boys, always hold them by the sides :-/
  9. mars-bar-man
    17 Apr 2009
    I was, trying to unscrew the top to change the balde, it was stiff, so twisted harder, and my grip gave.. then blood. Lots of it.
  10. Tichinde
    1 Sep 2010
    Same, finger and thumb on the sides, failure to budge, applied more pressure, *sping* noise and blade embedded in my thumb.
  11. LithiumDesign
    23 Jul 2009
    Ouchie! How often do you guys change blades?
    Sent from my HTC One S using Tapatalk 2
  12. mars-bar-man
    17 Apr 2009
    If I haven't had a shave in a while (4-5+ days), I'll change the blade, failing that, every 6 or so shaves.
  13. Nexxo
    23 Oct 2001
    Me, about every five shaves. When the blade starts to tug, you know it's time.
    Don't overtighten the head...
  14. kirk46
    kirk46 Cheesecake Nom Nom
    9 Jun 2012
    I cant get on with a wet shave :mad:
    Tried it many times and i find it very painfull as the shaver pulls my hair rather than cuts :what:
    And i have to shave everyday... thats how fast it grows :eek:
    Sent from my GT-I9300 using Tapatalk 2
  15. Jeevus
    Jeevus Member
    6 Sep 2009
    @ Kirk46
    I shave everyday as well and don't have this problem. It sounds like it might be the angle you're holding the razor at. If I hold it closer to the 90 degree angle than say at 45 degrees, it usually pulls more.
  16. TheBlackSwordsMan
    16 Aug 2009
    It depend of the blades, between 3 and 6 for me. I'm DE shaving for more than a year and never had this problem : / But from what I heard, he is not the first to cut himself with a Merkur Futur, it is a slipery razor.
  17. LithiumDesign
    23 Jul 2009
    I figured it would be about 4 shaves, depending on the amount of passes you do and how thick yer beard is!
    I've noticed the derby blades have 1, 2, 3 and 4 written on each side, can you flip the blade and use it 'twice' as it were?
    Just had my best shave to date, almost BBS, I don't know if it's my technique, razor, or blade I'm using but I can't quite get rid of that last little bit on the end of my chin and my sideburns... Using derby blades at the mo, will 7 o'clocks give me an even closer shave? Or do I need a more aggressive razor?
    Edit: correcting some bleddy awful grammar...
  18. Almightyrastus
    21 Mar 2002
    The numbers are one of the biggest 'mysteries' in wet shaving. Outside of the factory and quality control they mean nothing at all.
  19. saspro
    saspro IT monkey
    23 Apr 2009
    They relate to the grinders in the factory that sharpen the edge.
    They put the numbers on the blade so quality control can see if one isn't working properly.
    3-4 shaves for me per blade, 2-3 passes per shave.
  20. CarlT2001
    CarlT2001 New Member
    23 Jul 2004
    Some people insist that blade flipping works. Personally I have no idea how they think it makes a difference. There is only one edge, turning it upside down does not change it.
