Case Mod - In Progress Saint Louis Cardinals theme case! - COMPLETE! 6/11
Discussion in 'Project Logs' started by TheGreatSatan, 28 Apr 2013.
  1. TheGreatSatan
    TheGreatSatan Dark Lord of BT!
    5 Aug 2005
    A Mod for my Wife!! She is a Mega Fan!
    The case I'm using is the Fractal Design Arc Midi
    I need to tear it down for painting. The first to go is one of the drive bay cages. I will not be putting it back in either because I'll only have two drives and there's room on the bottom
    Next, comes everything else that's not part of the base steel frame
    Can you believe this thick filter was on the top? Why the hell would they use such a thick filter over an exhaust fan??
    The front comes off too with it's lone fan
    There she is....the frame
    I start painting with a light red coat
    The front and top mesh pieces are painted white
    and the front and top panels are painted red
    Once dry, I reassemble the top without the thick mesh filter
    The front will obviously have a mesh filter, so that's where I start
    There will be two 140mm intake fans
    under the completed bezel
    I need to paint the panel controls and ports area too
    And put it back on the case
    Once the frame is dry, all the fans and accessories go back in
    Now that the top panel and front bezel are on, they go back on the case
    I added a matching DVD burner
    The right panel finally gets its top coat
  2. Kovoet
    Kovoet What's a Dremel?
    26 Aug 2009
    Looking go so far. What size logo you going to use
  3. flame696
    flame696 Terminating People Since 1980....
    15 May 2009
    Great work always look forward to your builds. Have a few questions regarding paint,
    1. How many coats do you apply?
    2. Do you wet sand in between coats?
    3. Also do you use lacquer??
    Only need to know as you paint finish is always fantastic
  4. TheGreatSatan
    5 Aug 2005
    This new paint has paint and primer in one, so three.
    Yes, about 2000 grit
    No
  5. TheGreatSatan
    5 Aug 2005
    I just slapped a BIG decal on the right side because that's what the wifey wants.
    It looks good anyway
    and then I started painting left side and ran out paint!!
  6. TheGreatSatan
    5 Aug 2005
    I intend to use the other 5.25 bay for a light controller. The NZXT Hue is great little toy, but it's not gonna match like this
    So I strip it down to the core components
    The top piece, which is the largest will be white. The under layer will be red, when I get more paint...
  7. TheGreatSatan
    5 Aug 2005
    I got the Specs lined up:
    i5 3570K
    Asrock Z77 Extreme 6
    EVGA GTX 580 DS Superclocked
    8GB DDR3-1866 Corsair Dominator Platinum & OCZ Vertex 3 240GB
    Corsair H110 Cooler
  8. flame696
    15 May 2009
    does the paint not chip and will it be durable without lacquer? Sorry for the questions.... Lovely build though
  9. GregTheRotter
    GregTheRotter Minimodder
    9 Aug 2008
    Why the 580? Did you have it sitting spare?
  10. TheGreatSatan
    5 Aug 2005
    I did have a spare. My wife will use this machine maybe once a week for an hour tops to print coupons!! I thought a 580 would be hilarious!
    Should I have given it away here instead??
    I never do a clear coat. I've never had a problem with the paint chipping and shiny cases don't do it for me
  11. TheGreatSatan
    5 Aug 2005
    I picked up some more red paint for the mesh
    And then reassembled the panel
    Then I painted some thumb screws to match
    Now the bays are back together
  12. DraC_01
    DraC_01 What's a Dremel?
    21 Apr 2013
    Can I just say, awesome paint job, what kind of spray paint did you use? Automotive? And if you do sell that 580, I'd be more than happy to buy it, could sli it in my bro's comp :p
  13. TheGreatSatan
    5 Aug 2005
    I got an awesome deal on it - $212!!
  14. TheGreatSatan
    5 Aug 2005
    I put the balls on the knobs
    I don't know if I like it, what do you think?
    I want an STL logo on the front of the case and tried ordering it through a metal cutter. The problem is that it's a copyrighted symbol and no one will cut it for me!
    So, here I go:
    I slowly widdle it away
    Till it's done
    I just have to strip, sand, paint, and then mount it
  15. Asouter
    Asouter --------
    18 Jan 2012
    Not so sure about the base ball knobs (that just sounds sooo wrong :hehe:) They're definitely different but really stand out, S'pose you could graduate them 0 to 11 (that a whole one louder than 10)... Nice colours on the case though...
  16. KrunchR
    KrunchR What's a Dremel?
    22 Apr 2008
    Yeah, I would lose the baseballs. Paint looks good.
  17. flame696
    15 May 2009
    +1 on losing the baseballs. I think they are a bit big and just over powers the fan controller. If they were smaller they might look good
  18. TheGreatSatan
    5 Aug 2005
    I agree, the knobs are going. I'm gonna order one more and turn them into case feet instead.
  19. Asouter
    Asouter --------
    18 Jan 2012
    What would they look like cut in half ? they'd not stand out as much
  20. TheGreatSatan
    5 Aug 2005
    They would still be just as wide
