Case Mod - In Progress Saint Louis Cardinals theme case! - COMPLETE! 6/11
Discussion in 'Project Logs' started by TheGreatSatan, 28 Apr 2013.
  1. TheGreatSatan
    TheGreatSatan Member for 17 years!
    5 Aug 2005
    So, I admit it, the ball knobs look stupid. I've decided to use them as feet instead, but had to order one more
    On to the top of the case. I have special nut that lets me add a screw without having to go through the panel
    Then I ran a bolt through the bat
    And added it to the top of the case
    And I used a thin wire to secure the bottom of the bat to the top of the case. This will be for decoration only and NOT a handle.
    And I'll need to use a wood filler to cover the bolt
    But first I used my dremel to make the screw in the bat a little more concave
    It's only gonna take an hour to dry, but I'm giving it 24!
  2. Maki role
    Maki role Dale you're on a roll... Lover of bit-tech
    9 Jan 2012
    Wow those balls make perfect case feet actually, just the right size, plus they're not too in your face that way. Not too sure about the bat though. Is it going to have some other things around it so that it doesn't look a little lonely? Currently it sticks out a little too much IMO, doesn't fit with be lines of the case. Looking forward to seeing where this is headed though!
  3. Asouter
    Asouter --------
    18 Jan 2012
    The baseballs definitely look better as case feet
  4. 666painkiller
    666painkiller If only....
    23 Jun 2010
    love the feet!!!!
  5. TheGreatSatan
    5 Aug 2005
    I decided to up the ante and go from the i5 3570K to the i7 3770K
    Overkill? Most certainly!!
    And I won't be using the Dominators I posted earlier, because I got these red and white Corsair Vengeance DDR3-1600 LP's.
    Is 16GB of RAM overkill?. Indeed it is!
    I sanded down the filler to make the bat's surface flush
    Then I cut out the mounting holes in the STL logo
    After I cleaned up all the rough edges, I painted the logo
    I also painted the screws and sleeves that will go under the logo
  6. TheGreatSatan
    5 Aug 2005
    Another change to the specs.
    Since the new Haswell's are just about here, I'm going to get her the new i7 4770K and a new board (I think the Z87-UD4H). Also, one of my GTX 580's is bad, so I'm selling the good one and upgrading to an MSI Twin Frozr GTX 680 4GB!!
  7. Asouter
    Asouter --------
    18 Jan 2012
    Nice specs, I'm holding out for the Haswell kit too, or I might be tempted if the Z77 stuff drops in price when the new stuff is released
  8. TheGreatSatan
    5 Aug 2005
    I put the STL logo on the front of the case with spacers
    After several spec changes, I'm making another. I got a new Motherboard that just came out today! The Gigabyte Z87X-UD4H, socket 1150.
    And the new i7 4770K!
    I just need to fix the paint on the left panel. It's been giving me a headache
  9. Mechh69
    Mechh69 I think we can make that fit
    16 Sep 2009
    Nice job so far. I'm not a baseball fan but it looks good none the less. That's a really nice coupon printer!
    That orange peel on the case side looks like a little lubricant got on there I would strip that section completely and rub it down with alcohol to remove any other contaminant before I panted again.
    Keep up the good work. I look forward to seeing the finished product.
  10. TheGreatSatan
    5 Aug 2005
    I got the new motherboard in the case with the new i7 4770K processor
    I'll be using Corsair Vengeance Low Profile RAM with two white and two red sticks, 16GB total
    I really wanted to use the Corsair H110 closed loop cooler, but it did not fit on the top of the case! So, I'm going with an old favorite instead: The Cooler Master S524 air cooler
    As usual I only use this cooler with a 140mm fan. I have these really nice Gelid fans with NanoFlux bearings, but they're the wrong color
    I popped off the fan blades for a repaint. I wanted to use red, but I'm all out! So white it'll be
    While it dries I put the 240GB SSD in
    And now it's all in. I just need the video card....
  11. TheGreatSatan
    5 Aug 2005
    After tons of fun painting the left panel, it's finally done. First up, add the applique I ordered from CrazyPC
    I've been meaning to add a real baseball to this case and not just the little feet
    But first I have to drill a hole through one
    And feeding an acrylic tube through it
    Then I just had to drill the drive bay to hold it in
  12. TheGreatSatan
    5 Aug 2005
    I got rid of the light controller and now I'm using the NZXT Aperature for the front panel. I like having a card reader and a couple more USB 3.0 ports available
    I need to disassemble it to paint
    Red and white like the rest
    It only takes one night to fully dry
  13. TheGreatSatan
    5 Aug 2005
    My 4GB MSI GTX 680 Twin Frozr arrived
    And it works!
  14. TheGreatSatan
    5 Aug 2005
    The last thing I had on order for this project was these red and white PCIe cable extensions
    I've made the red and white theme pretty obvious, but still like the 24 pin in just white. Now all the cables are tied off behind the motherboard.
    Besides what is already connected by default on the power supply, all I need is a single line for the two SATA devices
  15. TheGreatSatan
    5 Aug 2005
    I needed to use a little astro turf that I got for FREE as a sample size
    The video card looks odd. It needs to look like it belongs in the same theme
    I use a thin cardboard backer to protect the PCB
    Then I cut the mesh and painted it red
    And I finally painted the pole white
    Once the mesh was dry it went on the back of the card
  16. Cown
    Cown Minimodder
    25 Feb 2012
    Looking good :)
    Like the white backplate with red mesh on the gfx, nice touch.
  17. TheGreatSatan
    5 Aug 2005
    I finally broke down and got the 24 Pin cable to match
    COMPLETION!
    Specs:
    Intel i7 4770K
    Gigabyte Z87X-UD4H
    16GB (4GB x4) Corsair Vengeance LP
    MSI GTX 680 4GB Twin Frozr
    240GB SSD
    850 Watt PC Power & Cooling
    Fractal Design Arc Midi​
  18. phelan
    phelan What's a Dremel?
    9 Dec 2012
    Just found this looking at HUE pics online. Sweet build!
