Saitek eclipse II
Discussion in 'Hardware' started by Jackarias, 27 Feb 2008.
  1. Jackarias
    Jackarias What's a Dremel?
    13 Jul 2007
    Hey
    I just bought this new keyboard today, because my old one was old and grimey.. and not multicoloured. I figured a keyboard aimed at gamers would be allow you to press more than two buttons simultaneously.
    Basically, I just wondered if there's away to be able to change the amount of buttons that your pc responds to being pressed at the same time.
    For example, I play on cs 1.6 and ventrilo.
    If I press shift to walk, w to go forward. I then want to say something to my friends on vent (capslock button for ease of reach). However, now, I have to take my finger off either shift or w, or the pc doesnt register me pushing my push-to-talk key.
    What can I do?
    Thanks
  2. talladega
    talladega I'm Squidward
    18 Aug 2007
    I think there are certain buttons on all keyboards that cannot be pressed at the same time. Maybe im wrong?
  3. BUFF
    BUFF What's a Dremel?
    25 Mar 2005
    It isn't marketed as a gaming keyboard, merely a keyboard with backlit keys.
    I believe though that even the Logitech G15 has similar problems (as do other backlit keyboards).
  4. StevenJam
    StevenJam What's a Dremel?
    3 Feb 2008
    steelseries 6G can do 8 simultaneously
    there releasing 7G, i think that keyboard is back lit as said,
    Try using middle mouse pushed in for vent/ts works better, or voice activation .
  5. Guest-23315
    Guest-23315 Guest
    I think its something in windows.. I used to get beeps when I did it in 1.6..
  6. BUFF
    25 Mar 2005
    not backlit though.
    It's something to do with the extra traces & engineering it for the price point (i.e. it's technically possible if you were willing to pay a lot more for it).
  7. StevenJam
    3 Feb 2008
    buy a desktop lamp ;D
    and you get grey keys which are actually quite easy to see in the dark
  8. sheninat0r
    sheninat0r What's a Dremel?
    28 May 2007
    Razer boards [Tarantula and Lycosa, and maybe the Razer/Microsoft one too] can do up to 10 at a time.
  9. BUFF
    25 Mar 2005
    Tarantula isn't fully backlit (only 10 keys) & both are 3x the price of an Eclipse.
